M0 feather with RFM95 lora module
s1meon
Post by s1meon »
I've been using the M0 for a couple of days now, but this morning I went to upload a sketch and it wasn't recognised (couldn't see the board over COM Ports). I've followed Adafruit's advice and tried to send it into bootloader mode, but that doesn't work - the red LED doesn't flash or even light up. I'm using the same USB cable as yesterday, when it was working. The only sign of life on the board is the green LED which blinks when the usb is inserted or removed.
amigomaxwell
Re: M0 feather with RFM95 lora module
Post by amigomaxwell »
I did not ran into the same (COM port working for me) issue but I'd like to know if you got the LoRa radios to work with the Tx-Rx example on the web?
amigomaxwell
Actually, I got it to work with the help of the following topic. Basically they both need to be connected to the serial port to work, ie. none of them can be on their own on a usb-powered cable
viewtopic.php?p=915834&hilit=lora+m0#p915834
sorry for going off topic with your post, just wanted to add an answer
