XRAD'S Need a bit of C++ code to turn off onboard dotstar
Wearable electronics: boards, conductive materials, and projects from Adafruit!
XRAD
Post by XRAD »
using arduino IDE and Gemma M0: I have the updated dotstar lib. I have tried several variations of dotstar control...can;t get it to turn off....tired pins 7,8 and 3,4
anyone have a tip??
this does not work and locks the USB port....
#include <Adafruit_DotStar.h>
#define NUMPIXELS 1 // Number of LEDs in strip
#define DATAPIN   7//3
#define CLOCKPIN   8//4
Adafruit_DotStar strip = Adafruit_DotStar(
  NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_RGB);//or GRB
  strip.begin(); // Initialize pins for output
  strip.show();  // Turn all LEDs off
XRAD
Re: XRAD'S Need a bit of C++ code to turn off onboard dotstar
Post by XRAD »
So still no luck....using the below program crashes the USB port and windows error message pops up: Last USB device not recognized (but it was just fine before using Adafruit_DotStar.h)
I am using Win 11...
I can control the Dot on itsybitsy m4...but not on the Gemma...
any thoughts??
#include <Adafruit_DotStar.h>  //this is the most up to date version
#define DATAPIN    3//purple pins colors from gemma pinout pic
#define CLOCKPIN   4
                           NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
  strip.begin();
  strip.setBrightness(0);
  //strip.clear();
void loop(){}
adafruit2
Post by adafruit2 »
what if you add a Serial.begin(115200) at the start of setup()?
XRAD
Post by XRAD »
Ok...I tried your suggestion. No luck. And the Adafruit_Dotstar.h also crashes the USB on a known good working trinket M0....hmmmm
I do have the latest DotStart lib....
Dot Libs.jpg (178.14 KiB) Viewed 169 times
#define DATAPIN    3//from gemma pin pic
#define CLKPIN   4
//#define DOTSTAR_DATPIN INTERNAL_DS_DATA
//#define DOTSTAR_CLKPIN INTERNAL_DS_CLK
Adafruit_DotStar strip = Adafruit_DotStar(NUMPIXELS, DATAPIN, CLKPIN, DOTSTAR_BRG);
                           //NUMPIXELS, DOTSTAR_DATPIN, DOTSTAR_CLKPIN, DOTSTAR_BRG);
  Serial.begin(115200);
  strip.clear();
void loop(){}
adafruit2
Post by adafruit2 »
hmm cant replicate - using arduino 1.8.13 and latest BSP for gemma m0 - works just fine for us :/
// An example demonstrating how to control the Adafruit Dot Star RGB LED
// included on board the ItsyBitsy M4 board.
// There is only one pixel on the board
#define NUMPIXELS 1
//Use these pin definitions for the ItsyBitsy M4
#define DATAPIN    3
#define CLOCKPIN   4
Adafruit_DotStar strip(NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
  strip.show();  // Turn all LEDs off ASAP
  //rainbow(10);             // Flowing rainbow cycle along the whole strip
XRAD
Post by XRAD »
I have Arduino 1.8.19.....maybe it makes a difference....
I thought I had the newest boards module...I will check...
I was able to control the Dots with older arduino versions....
EDIT: I have the correct URL json and the boards package with all the adafruit M0 and M4 boards
EDIT2: I have AVR boards manager 1.8.5 and SAMD board manager 1.7.10
Thanks for replies!
XRAD
Post by XRAD »
Reloaded dotstar lib. No change..still crashes my USB port and dotstar does not change color or turn off on either my trinket M0's and my Gemma M0's.....
Gemma Dot pins: 3,4
Trinket Dot pins: 7,8
But dotstar example in IDE works just fine on M4 express itsybitsy....
For now, I can just physically remove the Dot off the board to save power.....not ideal..but I know it will work..lol
Return to “Wearables”
