"Adafruit_SPIFlash.h": Change SPI speed ATSAMD21
Tipo1000
Post by Tipo1000 »
I'm trying to change SPI clock speed from default 12MHz to 1MHz. How can I do this with ATSAMD21? I'm using Adafruit_SPIFlash library.
I tried what is below but it didn't work with ATSAMD21. With older Arduinos this was trivial I think...
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));  //This doesn't do anything
if (!flash.begin()) {
  Serial.println("Error, failed to initialize flash chip!");
  while(1) yield();
 SPI.setClockDivider(4); //Tried different dividers but code just hangs...
  while(1) yield();
Tipo
Return to “Arduino”
