I purchased https://www.adafruit.com/product/4099 and I will like to know what are the connector pins. They are big and dented and do not fit in breadboard.
What would be the jack connectors I can use to test on a breadboard?
The white cable jumper is not part of the product, just for reference size.
Thank you,
Pierre
SHT-30 #4099 connector pin
- rooppoorali
Re: SHT-30 #4099 connector pin
I think the only way to connect this sensor to the breadboard is to solder four male-to-male jumpers.
- Pie2re
Looking around I see that they are just crimped ferrule sleeves. I should cut the wires and crimp new one that fit a breadboard.
Why was the purpose for the SHT to come with these?
Does anybody know what are the AG gauge for the wires? It is not on this datasheet.
https://cdn-shop.adafruit.com/product-f ... asheet.pdf
- adafruit_support_carter
Yep, those are just crimped ferrules. They are mainly intended for use with screw down terminal blocks, like these:
https://www.adafruit.com/product/724
The ferrules simply keep the stranded wires from becoming a mess.
- Pie2re
Great, this is going messily forward.
Following a previous post on TPL5110, it is working as expected.
Thank you,
Pierre
Thank you,
Pierre
- Screen Shot 2022-09-20 at 9.41.51 AM.png (774.75 KiB) Viewed 22 times
