Does Matrix Portal M4 support panels with FM6126A chip?
- dougiejones
I have a couple of panels that run fine with the SmartLed shield (https://www.adafruit.com/product/1902), but both refuse to work with MatrixPortal. Any way to make them work? Thanks!
- dastels
Re: Does Matrix Portal M4 support panels with FM6126A chip?
Both boards work with HUB75 panels. If they are HUB75 panels, they should work with the MatrixPortal.
Please explain what you mean by "refuse to work".
- dougiejones
Heh. "refuse to work" == "the program is running, but the panel is completely blank". I suspect the FM6126 chip is not supported by rgbmatrix/protomatter.
- dastels
Perhaps not. What panels do you have?
- dougiejones
It says: P3-6432-2121-16S-D1.0 got them from eBay a couple of years ago.
- dougiejones
For what it's worth, SmartMatrix library (which works) has this:
// experimental FM6126A support on ESP32 without external latch: make LAT pulse 3x clocks wide, matching the FM6126A "DATA_LATCH" command (and not the "RESET_OEN" command)
if(optionFlags & SMARTMATRIX_OPTIONS_FM6126A_RESET_AT_START) {
if((refreshBufferPosition) == PIXELS_PER_LATCH-2) v|=BIT_LAT;
if((refreshBufferPosition) == PIXELS_PER_LATCH-3) v|=BIT_LAT;
- dastels
OK, so they are essentially an unknown. Have you tried getting the SmartMatrix library working on the MatrixPortal?
- dougiejones
Regrettably, no. SmatrtMatrix seems to support only Teensy and ESP32.
- adafruit2
yeah we dont own or sell any of those chip panels - if you're able to add FM6126 to protomatter we'd gladly take a pull request!
- dougiejones
Ok. I got it working. Not sure if anyone needs this, but here: https://github.com/adafruit/Adafruit_Pr ... er/pull/52
- adafruit2
