We have ordered an item "Barcode Reader/Scanner Module - CCD Camera - USB Interface", Product ID: 1203
Order #2918695-1997890378, Order Date : September 11, 2022 @ 7:30 AM.
The received item is having a damaged wire as its been partially severed/divided and it can come a part easily.
We have tested the item and it was not giving the necessary response/feedback from it.
I am attaching the picture's of it.
Damaged Part/item
- zeroohm
Damaged Part/item
- WhatsApp Image 2022-09-18 at 1.56.47 PM.jpeg (57.84 KiB) Viewed 110 times
- WhatsApp Image 2022-09-18 at 1.56.45 PM.jpeg (53.41 KiB) Viewed 110 times
- WhatsApp Image 2022-09-18 at 1.55.22 PM.jpeg (51.89 KiB) Viewed 110 times
- Franklin97355
Re: Damaged Part/item
Are you in the US? If it is working and just loose you might be able to stabilize it with hot glue or silicone. Let me know, thanks.
- zeroohm
Thank you for the response.
We are not in UAE. Actually this is for one of our client. The client them self saw the damage at the time of collecting and did the test to make sure if its working or not and it turned out to be not working.
- Franklin97355
Not the UAE, The United States, that makes a difference on how we can handle this.
- zeroohm
That's what i was mentioning, we are not in United States. We are in UAE.
So what can we do about this situation.
- adafruit2
zero, just to check, does it *otherwise work* fine? if theres any other issues we dont want to replace twice as it is going to take time to send replacements to UAE
- zeroohm
Its also not working, we are not getting the response from the item.
- zeroohm
The client of ours has cancelled the order due to this issue, so can we do the refund for this item or do something with else other than the replacement. Cause this product was bought just for a specific client and their dead line came.
Let me know what should we do.
- adafruit2
sure email support@adafruit for a refund
