Line Laser Diode Beam Dimensions
- guercimj
In the description of item 1057, it says the beam has a spread of 120 degrees which results in a 150mm wide beam at 50mm. One of the numbers must be off or rounded, as this places the focal point outside of the diode body. What are the correct numbers?
- laser beam.jpg (38.62 KiB) Viewed 1241 times
Re: Line Laser Diode Beam Dimensions
The beam spread figures are approximate since there is no hard cutoff. The beam intensity gradually fades out at the extremes.
