Hello All,
I am trying to find a suitable controller that can communicate with 3rd party modules using Industrial Ethernet protocols such as Profinet / Profibus / Ethernet/IP master.
Are there any Adafruit boards that support the above mentioned protocols and is there library support available from Adafruit for implementing the same.
Any advise as to where I can find such a controller is most welcome and highly appreciated. Any support or help would be extremely useful to me.
Looking forward to your response.
Best Regards,
Bhindhiya
Support for Industrial Ethernet Protocols
- Bhindhiya97
Re: Support for Industrial Ethernet Protocols
We do not have such a library. But you can find one here: https://gitee.com/byronartest/Profinet-for-Arduino
See the ReadMe file for Arduino board compatibility.
- westfw
There can be three "parts" to "Industrial Ethernet."Industrial Ethernet protocols such as Profinet / Profibus / Ethernet/IP master.
- Software-level stuff - these will use standard ethernet hardware but run "industrial" protocols.
- Modified MAC layer, such as "TSN" (Time Sensitive Networking) - Since the CSMA/CD protocol used by regular ethernet is somewhat non-deterministic, replacements have been invented for situations that are very delay-critical. This may require a specialized ethernet controller, or special configuration of an existing MAC. (the "MAC" or Media Access Controller, is the Ethernet controller that programmers mostly deal with, frequently incorporated into advanced microcontrollers.)
- Modified Physical Layer - The 8pin RJ45 jack/plug is pretty standard for "regular ethernet", but there are some alternatives aimed at industrial applications. Most recently is probably "Single Pair Ethernet" designed to support transmission (and power) over a single twisted pair. It also features more robust connectors. Typically, this would require a different "PHY" chip than normal Ethernet.
(2) and (3) may require specialized hardware. I'm not aware of any arduino-class boards that support any specialized versions of Ethernet. (but, I haven't been paying much attention, either.)
(OTTH, I don't see Single Pair Ethernet Switches on consumer sites like Amazon or Newegg, so perhaps it's "newer than new.")
So you need to further nail down exactly what you need.
