Hello! I am new to the raspberry pi world. I have a project where I want to use the stepper motor hat from adafruit (https://learn.adafruit.com/adafruit-dc- ... ing-motors) along with some type of homing mechanism (e.g. hall effect sensor). Does anyone have any guidance on what type of homing mechanism I could use and how to connect it to the adafruit stepper motor hat?
EDIT: I also found this which seems related/helpful but I'm not sure how to parse the answer: viewtopic.php?f=8&t=115770
Homing a stepper motor hat for my raspberry pi
- danielgeri
Re: Homing a stepper motor hat for my raspberry pi
There are lots of options for a home sensor: Mechanical microswitches, optical slot sensors, hall effect and inductive proximity sensors are some of the more commonly used ones. The choice often depends on the mechanical design of the system and what mounting options there are. From a coding perspective, they are all pretty much the same.
- danielgeri
I see! Super helpful! How would I connect a hall sensor to the stepper motor hat linked above? Would that even be the correct place to connect the sensor to?
As noted in the thread you linked, you can use any of the GPIO pins indicated on the photo. These signals are just passed through from the Pi header and are not used by the HAT itself. You can connect the sensor to one of these pins and configure it as a digital input: https://learn.adafruit.com/circuitpytho ... tal-inputs
