import time
import ssl
from random import randint
import microcontroller
import socketpool
import wifi
import board
import neopixel
import adafruit_minimqtt.adafruit_minimqtt as MQTT
from adafruit_io.adafruit_io import IO_MQTT
import busio
import adafruit_sgp30
import math
from adafruit_bme280 import basic as adafruit_bme280
#Initialize I2C and Calculations
i2c = board.I2C() # uses board.SCL and board.SDA
bme280 = adafruit_bme280.Adafruit_BME280_I2C(i2c)
# Set local sea level pressure in milibars
bme280.sea_level_pressure = 1013.4
# Calculate Dew Point with "Magnus" formula
b = 17.62
c = 243.12
gamma = (b * bme280.temperature /(c + bme280.temperature)) + math.log(bme280.humidity / 100.0)
dewpoint = (c * gamma) / (b - gamma)
#Secrets Imports
try:
from secrets import secrets
except ImportError:
print("WiFi and Adafruit IO credentials are kept in secrets.py - please add them there!")
raise
# Add your Adafruit IO Username and Key to secrets.py
# (visit io.adafruit.com if you need to create an account,
# or if you need to obtain your Adafruit IO key.)
aio_username = secrets["aio_username"]
aio_key = secrets["aio_key"]
# WiFi
try:
print("Connecting to %s" % secrets["ssid"])
wifi.radio.connect(secrets["ssid"], secrets["password"])
print("Connected to %s!" % secrets["ssid"])
# Wi-Fi connectivity fails with error messages, not specific errors, so this except is broad.
except Exception as e: # pylint: disable=broad-except
print("Failed to connect to WiFi. Error:", e, "\nBoard will hard reset in 30 seconds.")
time.sleep(30)
microcontroller.reset()
# Initialise NeoPixel
#pixel = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.3)
# Define callback functions which will be called when certain events happen.
def connected(client):
print("Connected to Adafruit IO!")
# Subscribe to Adafruit IO feed called "Temperature1827"
client.subscribe("Temperature1827","Humidity1827")
def message(client, feed_id, payload): # pylint: disable=unused-argument
print("Feeds Received New Values".format(feed_id, payload))
# Create a socket pool
pool = socketpool.SocketPool(wifi.radio)
# Initialize a new MQTT Client object
mqtt_client = MQTT.MQTT(
broker="io.adafruit.com",
username=secrets["aio_username"],
password=secrets["aio_key"],
socket_pool=pool,
ssl_context=ssl.create_default_context(),
# Initialize Adafruit IO MQTT "helper"
io = IO_MQTT(mqtt_client)
# Set up the callback methods above
io.on_connect = connected
io.on_message = message
#timestamp = 0
while True:
try:
# If Adafruit IO is not connected...
if not io.is_connected:
# Connect the client to the MQTT broker.
print("Connecting to Adafruit IO...")
io.connect()
# Explicitly pump the message loop.
io.loop()
# Obtain the "Temperature1827" value, print it and publish it to Adafruit IO every 10 seconds.
while True:
temp_f = (bme280.temperature * (9/5) + 32)
humid = bme280.humidity
print("Temperature: %0.2f ºF" % temp_f)
print("Humidity: %0.2f %" % humid)
io.publish("Temperature1827", temp_f)
io.publish("Humidity1827", humid)
time.sleep(10)
# Adafruit IO fails with internal error types and WiFi fails with specific messages.
# This except is broad to handle any possible failure.
print("Failed to get or send data, or connect. Error:", e,
time.sleep(30)
