I have a large perspex wheel that is connected to a motor, as this wheel turns a single dot on the wheel needs to be detected to count the number of rotations.
The speed (RPM) of the motor will then be worked out by counting the dots detected per minute. Can anyone help on how to sense / read the dots?
Spinning wheel, dot detection
Re: Spinning wheel, dot detection
See this guide for some examples: https://learn.adafruit.com/pro-trinket-tachometer
- splatten
Thank you @adafruit_support_bill
For a perspex wheel, a slot-type detector might be a better choice than the reflective sensor: https://www.adafruit.com/product/3986
In the code, you would change the interrupt mode from FALLING to RISING in the call to attachInterrupt().
