Unable to connect to Adafruit IO
kyriatic
Post by kyriatic »
I've been trying to make the PyPortal Pet planter dashboard to work using the provided code and I can connect to Wifi, but when I try to connect to Adafruit IO I get the error below. Can anyone help me figure this out?
Connecting to Adafruit IO...
File "code.py", line 223, in <module>
File "/lib/adafruit_io/adafruit_io.py", line 111, in connect
AdafruitIO_MQTTError: MQTT Error: Unable to connect to Adafruit IO.
>Adafruit CircuitPython 7.3.3 on 2022-08-29; Adafruit PyPortal Titano with samd51j20
Code:
# SPDX-FileCopyrightText: 2020 Brent Rubell for Adafruit Industries
import time
import board
import busio
from digitalio import DigitalInOut
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi, adafruit_esp32spi_wifimanager
import adafruit_imageload
import displayio
import neopixel
from adafruit_bitmap_font import bitmap_font
from adafruit_display_text.label import Label
from adafruit_io.adafruit_io import IO_MQTT
import adafruit_minimqtt.adafruit_minimqtt as MQTT
from adafruit_pyportal import PyPortal
from adafruit_seesaw.seesaw import Seesaw
from simpleio import map_range
#---| User Config |---------------
# How often to poll the soil sensor, in seconds
# Polling every 30 seconds or more may cause connection timeouts
DELAY_SENSOR = 15
# How often to send data to adafruit.io, in minutes
DELAY_PUBLISH = 5
# Maximum soil moisture measurement
SOIL_LEVEL_MAX = 500.0
# Minimum soil moisture measurement
SOIL_LEVEL_MIN= 350.0
#---| End User Config |---------------
# Background image
BACKGROUND = "/images/roots.bmp"
# Icons for water level and temperature
ICON_LEVEL = "/images/icon-wetness.bmp"
ICON_TEMP = "/images/icon-temp.bmp"
WATER_COLOR = 0x16549E
# Audio files
wav_water_high = "/sounds/water-high.wav"
wav_water_low = "/sounds/water-low.wav"
# the current working directory (where this file is)
cwd = ("/"+__file__).rsplit('/', 1)[0]
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# Set up i2c bus
i2c_bus = busio.I2C(board.SCL, board.SDA)
# Initialize soil sensor (s.s)
ss = Seesaw(i2c_bus, addr=0x36)
# PyPortal ESP32 AirLift Pins
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
status_light = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.2)
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
# Initialize PyPortal Display
display = board.DISPLAY
WIDTH = board.DISPLAY.width
HEIGHT = board.DISPLAY.height
# Initialize new PyPortal object
pyportal = PyPortal(esp=esp,
                    external_spi=spi)
# Set backlight level
pyportal.set_backlight(0.5)
# Create a new DisplayIO group
splash = displayio.Group()
# show splash group
display.show(splash)
# Palette for water bitmap
palette = displayio.Palette(2)
palette[0] = 0x000000
palette[1] = WATER_COLOR
palette.make_transparent(0)
# Create water bitmap
water_bmp = displayio.Bitmap(display.width, display.height, len(palette))
water = displayio.TileGrid(water_bmp, pixel_shader=palette)
splash.append(water)
print("drawing background..")
# Load background image
try:
    bg_bitmap, bg_palette = adafruit_imageload.load(BACKGROUND,
                                                    bitmap=displayio.Bitmap,
                                                    palette=displayio.Palette)
# Or just use solid color
except (OSError, TypeError):
    BACKGROUND = BACKGROUND if isinstance(BACKGROUND, int) else 0x000000
    bg_bitmap = displayio.Bitmap(display.width, display.height, 1)
    bg_palette = displayio.Palette(1)
    bg_palette[0] = BACKGROUND
bg_palette.make_transparent(0)
background = displayio.TileGrid(bg_bitmap, pixel_shader=bg_palette)
# Add background to display
splash.append(background)
print('loading fonts...')
# Fonts within /fonts/ folder
font = cwd+"/fonts/GothamBlack-50.bdf"
font_small = cwd+"/fonts/GothamBlack-25.bdf"
# pylint: disable=syntax-error
data_glyphs = b'0123456789FC-* '
font = bitmap_font.load_font(font)
font.load_glyphs(data_glyphs)
font_small = bitmap_font.load_font(font_small)
full_glyphs = b'0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ-,.: '
font_small.load_glyphs(full_glyphs)
# Label to display Adafruit IO status
label_status = Label(font_small)
label_status.x = 305
label_status.y = 10
splash.append(label_status)
# Create a label to display the temperature
label_temp = Label(font)
label_temp.x = 35
label_temp.y = 300
splash.append(label_temp)
# Create a label to display the water level
label_level = Label(font)
label_level.x = display.width - 130
label_level.y = 300
splash.append(label_level)
print('loading icons...')
# Load temperature icon
icon_tmp_bitmap, icon_palette = adafruit_imageload.load(ICON_TEMP,
icon_palette.make_transparent(0)
icon_tmp_bitmap = displayio.TileGrid(icon_tmp_bitmap,
                                     pixel_shader=icon_palette,
                                     x=0, y=280)
splash.append(icon_tmp_bitmap)
# Load level icon
icon_lvl_bitmap, icon_palette = adafruit_imageload.load(ICON_LEVEL,
icon_lvl_bitmap = displayio.TileGrid(icon_lvl_bitmap,
                                     x=315, y=280)
splash.append(icon_lvl_bitmap)
# Connect to WiFi
label_status.text = "Connecting..."
while not esp.is_connected:
    try:
        wifi.connect()
    except (RuntimeError, ConnectionError) as e:
        print("could not connect to AP, retrying: ",e)
        wifi.reset()
        continue
print("Connected to WiFi!")
# Initialize MQTT interface with the esp interface
MQTT.set_socket(socket, esp)
# Initialize a new MQTT Client object
mqtt_client = MQTT.MQTT(broker="io.adafruit.com",
                        username=secrets["aio_user"],
                        password=secrets["aio_key"])
# Adafruit IO Callback Methods
# pylint: disable=unused-argument
def connected(client):
    # Connected function will be called when the client is connected to Adafruit IO.
    print('Connected to Adafruit IO!')
def subscribe(client, userdata, topic, granted_qos):
    # This method is called when the client subscribes to a new feed.
    print('Subscribed to {0} with QOS level {1}'.format(topic, granted_qos))
def disconnected(client):
    # Disconnected function will be called if the client disconnects
    # from the Adafruit IO MQTT broker.
    print("Disconnected from Adafruit IO!")
# Initialize an Adafruit IO MQTT Client
io = IO_MQTT(mqtt_client)
# Connect the callback methods defined above to the Adafruit IO MQTT Client
io.on_connect = connected
io.on_subscribe = subscribe
io.on_disconnect = disconnected
# Connect to Adafruit IO
print("Connecting to Adafruit IO...")
io.connect()
label_status.text = " "
print("Connected!")
fill_val = 0.0
def fill_water(fill_percent):
    """Fills the background water.
    :param float fill_percent: Percentage of the display to fill.
    assert fill_percent <= 1.0, "Water fill value may not be > 100%"
    # pylint: disable=global-statement
    global fill_val
    if fill_val > fill_percent:
        for _y in range(int((board.DISPLAY.height-1) - ((board.DISPLAY.height-1)*fill_val)),
                        int((board.DISPLAY.height-1) - ((board.DISPLAY.height-1)*fill_percent))):
            for _x in range(1, board.DISPLAY.width-1):
                water_bmp[_x, _y] = 0
    else:
        for _y in range(board.DISPLAY.height-1,
                        (board.DISPLAY.height-1) - ((board.DISPLAY.height-1)*fill_percent), -1):
                water_bmp[_x, _y] = 1
    fill_val = fill_percent
def display_temperature(temp_val, is_celsius=False):
    """Displays the temperature from the STEMMA soil sensor
    on the PyPortal Titano.
    :param float temp: Temperature value.
    :param bool is_celsius:
    if not is_celsius:
        temp_val = (temp_val * 9 / 5) + 32 - 15
        print('Temperature: %0.0fF'%temp_val)
        label_temp.text = '%0.0fF'%temp_val
        return int(temp_val)
    else:
        print('Temperature: %0.0fC'%temp_val)
        label_temp.text = '%0.0fC'%temp_val
# initial reference time
initial = time.monotonic()
while True:
    # Explicitly pump the message loop
    # to keep the connection active
    try:
        io.loop()
    except (ValueError, RuntimeError, ConnectionError, OSError) as e:
        print("Failed to get data, retrying...\n", e)
        wifi.reset()
        continue
    now = time.monotonic()
    print("reading soil sensor...")
    # Read capactive
    moisture = ss.moisture_read()
    label_level.text = str(moisture)
    # Convert into percentage for filling the screen
    moisture_percentage = map_range(float(moisture), SOIL_LEVEL_MIN, SOIL_LEVEL_MAX, 0.0, 1.0)
    # Read temperature
    temp = ss.get_temp()
    temp = display_temperature(temp)
    # fill display
    print("filling disp..")
    fill_water(moisture_percentage)
    print("disp filled..")
    print("temp: " + str(temp) + "  moisture: " + str(moisture))
    # Play water level alarms
    if moisture <= SOIL_LEVEL_MIN:
        print("Playing low water level warning...")
        pyportal.play_file(wav_water_low)
    elif moisture >= SOIL_LEVEL_MAX:
        print("Playing high water level warning...")
        pyportal.play_file(wav_water_high)
    if now - initial > (DELAY_PUBLISH * 60):
        try:
            print("Publishing data to Adafruit IO...")
            label_status.text = "Sending to IO..."
            io.publish("moisture", moisture)
            io.publish("temperature", temp)
            print("Published")
            label_status.text = "Data Sent!"
            # reset timer
            initial = now
            label_status.text = "ERROR!"
            wifi.reset()
    time.sleep(DELAY_SENSOR)
dastels
Re: Unable to connect to Adafruit IO
Post by dastels »
Did you put your Adafruit IO credentials in secrets.py?
kyriatic
Post by kyriatic »
Hey Dave,
I did put my AIO username and my key in my secrets file.
dastels
Post by dastels »
With the correct keys?
kyriatic
Post by kyriatic »
Yes. Those specifically listed on my IO page.
dastels
Post by dastels »
Has it ever connected?
kyriatic
Post by kyriatic »
Not yet
kyriatic
Post by kyriatic »
I had been working on this issue for awhile with no results. Plug it in and try again and suddenly it started working without me making any changes. Thanks for trying to help Dave!
dastels
Post by dastels »
Take the win. The internet can be flakey. There are so many moving parts between you and what you're talking to, I'm usually impressed that it works at all.
