Hello all,
I want to use the STEMMA NON-LATCHING MINI RELAY to control power to a sensor. Now, the controller can provide 12V and 80ma. Is it possible to power and control the relay from 12V? I downloaded the schematics but there is no voltage ratings for the capacitors and resistors used. Transistor and diode look OK.
D Yones
STEMMA NON-LATCHING MINI RELAY max operating control voltage
- dyones
Re: STEMMA NON-LATCHING MINI RELAY max operating control voltage
The relay coil is rated for a nominal 3v and has a resistance of 64 ohms. Activating the relay with 12v will draw about 188mA and result in considerable heating.
- dyones
Thanks for the help. Does Adafruit have another relay module that can run from 12V?
All the relays we carry are designed for use with control voltages in the 3v-5v range. I'd check with Mouser or DigiKey. They both carry extensive ranges of relays.
- dyones
No problem. Thanks for your help.
