BFF for QT Py not reading battery voltage
CR34T0R
Post by CR34T0R »
I'm reading A2 on the LiPoly Charger BFF Add-On for QT Py
With the following code:
def get_voltage(pin):
    return (pin.value * 3.3) / 65536
And I'm getting:
2.20188V
While plugged in, also when unplugged voltage doesn't seem right.
Not sure what I'm doing wrong, I double checked everything.
qtpy and bff are connected with the suggested female header method, picture attached.
dastels
Re: BFF for QT Py not reading battery voltage
Post by dastels »
The voltage divider that A2 is connected to halves the voltage, so that what's on A2 will be less than 3.3v as required by the ADC. To compensate, double the result.
From https://learn.adafruit.com/adafruit-qt-py-charger-bff:
A simple voltage divider on the cathode side of the diode and connected to pin A2 will let your firmware detect basic modes: if the voltage is over 4.3V, it is probably plugged into USB. If the voltage is 4.2V or below its probably running on the Lipoly battery and you can roughly determine the battery state.
CR34T0R
Post by CR34T0R »
Makes a lot of sense, missed that completely.
Thank you!
CR34T0R
Post by CR34T0R »
dastels wrote: Thu Sep 22, 2022 9:58 am The voltage divider that A2 is connected to halves the voltage, so that what's on A2 will be less than 3.3v as required by the ADC. To compensate, double the result.
[/quote]
I ended up multiplying for 2.2 for correction calibrating the LC709203F battery gauge and a fully charged battery.
The lack of precision is to be expected I guess.
Is my compensation correct?
dastels
Post by dastels »
It will vary a bit due to resistor tolerances. The main goal for reading it on A2 is to be able to tell whether power is from USB or battery.
CR34T0R
Post by CR34T0R »
dastels wrote: Thu Sep 22, 2022 3:34 pm It will vary a bit due to resistor tolerances. The main goal for reading it on A2 is to be able to tell whether power is from USB or battery.
Got it, thanks.
