Im using 3 VL53L0X sensors with the arduino uno R3, and the code that i use is the following:
#include "Adafruit_VL53L0X.h"
// address we will assign for all 4 sensor
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
#define LOX3_ADDRESS 0x32
// set the pins to shutdown for all 4 sensors
#define SHT_LOX1 2
#define SHT_LOX2 3
#define SHT_LOX3 4
// objects for the vl53l0x
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox3 = Adafruit_VL53L0X();
void setID() {
//Serial.print(F("brake 1, "));
// all unreset
digitalWrite(SHT_LOX1, HIGH);
digitalWrite(SHT_LOX2, HIGH);
digitalWrite(SHT_LOX3, HIGH);
delay(10);
//Serial.print(F("brake 2, "));
// activating LOX1 and reseting LOX2,LOX3
digitalWrite(SHT_LOX2, LOW);
digitalWrite(SHT_LOX3, LOW);
delay(10);
Serial.print(F("brake 3, "));
delay(1000);
// initing LOX1
if(!lox1.begin(LOX1_ADDRESS)) {
Serial.print(F("brake 3.1, "));
Serial.println(F("Failed to boot first VL53L0X"));
delay(500);
while(1);
delay(10);
Serial.print(F("brake 4, "));
///************************* sensor 2 activation
// activating LOX2
delay(10);
Serial.print(F("brake 5, "));
//initing LOX2
if(!lox2.begin(LOX2_ADDRESS)) {
Serial.println(F("Failed to boot second VL53L0X"));
while(1);
delay(10);
Serial.print(F("brake 6, "));
///************************* sensor3 activation
// activating LOX3
delay(10);
//initing LOX3
if(!lox3.begin(LOX3_ADDRESS)) {
while(1);
void read_quad_sensors() {
// this holds the measurement
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
VL53L0X_RangingMeasurementData_t measure3;
int sensor1,sensor2,sensor3;
lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
lox3.rangingTest(&measure3, false); // pass in 'true' to get debug data printout!
// print sensor one reading
Serial.print(F("1: "));
if(measure1.RangeStatus != 4) { // if not out of range
sensor1 = measure1.RangeMilliMeter;
Serial.print(sensor1);
Serial.print(F("mm"));
} else {
Serial.print(F("Out of range"));
Serial.print(F(" "));
// print sensor two reading
Serial.print(F("2: "));
if(measure2.RangeStatus != 4) {
sensor2 = measure2.RangeMilliMeter;
Serial.print(sensor2);
} else {
Serial.print(F("3: "));
if(measure3.RangeStatus != 4) {
sensor3 = measure3.RangeMilliMeter;
Serial.print(sensor3);
} else {
Serial.println();
Serial.begin(115200);
// wait until serial port opens for native USB devices
while (! Serial) { delay(1); }
pinMode(SHT_LOX1, OUTPUT);
pinMode(SHT_LOX2, OUTPUT);
pinMode(SHT_LOX3, OUTPUT);
Serial.print(F("Shutdown pins inited..."));
digitalWrite(SHT_LOX1, LOW);
Serial.print(F("All three in reset mode...(pins are low) "));
Serial.println("Starting...");
setID();
read_quad_sensors();
delay(100);
my problem is that when im using 2 sensors it works just fine. and when im using 3 sensors it doesnt print "brake 4" or even "brake 3.1" and starting the setup all over again.
i would much appreciate if someone can please help me.
and i would to thank Robojax.com for the template of this code
