fill() function not working correctly on RGBw Neopixel strip
rjenn2
Post by rjenn2 »
I am trying to light a string of individually addressable RGBw LEDs red with no flashing, chasing, etc.. With the code I am using, the first LED lights up red, the second LED lights up green, and the third LED lights up blue. What am I doing incorrectly?
#define PIN 6 // input pin Neopixel is attached to
#define NUMPIXELS 4 // number of neopixels in strip
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
const int button = 9;
int buttonState = 0;
int relay = 12;
void setup()
pinMode(relay, OUTPUT);
pinMode(button, INPUT);
delay(500);
pixels.begin(); // Initialize the NeoPixel library.
pixels.show();
void loop()
buttonState = digitalRead(button);
delay(500);
if(buttonState == HIGH)
digitalWrite (relay, HIGH); // turn on relay
delay(100);
uint32_t red = pixels.Color(255, 0, 0, 0);
pixels.fill(red, 0, 4);
pixels.show();
delay(500);
digitalWrite (relay, LOW); // turn off relay
delay(100);
Last edited by adafruit_support_bill on Thu Sep 22, 2022 3:31 pm, edited 1 time in total.
Reason: fixed [code] tags
Re: fill() function not working correctly on RGBw Neopixel strip
You have defined your strip as NEO_GRB. Try defining it as NEO_GRBW.
rjenn2
Post by rjenn2 »
Thanks! That fixed it.
Return to “Arduino”
