First off-
Yes. the mute trace is OPEN ( came that way)
Yes, I have a speaker attached
Yes, I have power to the Crickit HAT
Yes, I've loaded and installed and sudo rebooted a million times
Yes, I'm up to date on all the packages and loaded the latest seasaw UF2
when I run the speaker tests the audio will always work- but out the hdmi only- i've tried everything i can think of to change the default audio device ( thinking that's the issue) but no matter what i do I can't get audio out the Crikit speaker port.I hear clicks and so forth on boot so I know the speaker is working. I also see reference to the volume controls not working for the i2s--- i see that as well in alsamixer-- i'm just stuck on getting it to go out port i want it to.
Crickit Hat No sound out speaker, only hdmi
- ewassung
Re: Crickit Hat No sound out speaker, only hdmi
Problem self-solved. I'd share the solution if I knew exactly what it was. In the end, and not surprisingly, more of a raspberry pi configuration issue than a Crickit Hat issue.
