I'm trying to connect three identical tlv493d --i2c capable-- sensors to my Pico running circuitpython.
The problem is that the Pico has only two i2c interfaces. Is there a way to create an additional i2c interface?
I know there exists some softi2c alternatives for micropython and Arduino, but I couldn't find anything for circuitpython. Some ideas?
Thank you in advance
Softi2c for circuitpython?
- adafruit_support_carter
Re: Softi2c for circuitpython?
Best option is to use an I2C muxer:
https://learn.adafruit.com/working-with ... -conflicts
Using additional I2C ports for dealing with address conflicts is not recommended.
- danhalbert
You can use bitbangio.I2C if you want, which is a "soft" I2C implementation. The hardware I2C implementations often work out better for idiosyncratic I2C devices.
