I have trouble with the Neopixel on the Feather ESP32 V2 ; every time I try to use it, the board hangs.
I even tried compiling the factory reset sketch from here : https://learn.adafruit.com/adafruit-esp ... tory-reset, and the program ends up with this error :
13:14:36.063 -> abort() was called at PC 0x40086823 on core 1
13:14:36.063 ->
13:14:36.063 ->
13:14:36.063 -> Backtrace:0x40084199:0x3ffb26100x4008d33d:0x3ffb2630 0x4009266d:0x3ffb2650 0x40086823:0x3ffb26d0 0x4008696d:0x3ffb2700 0x400d8850:0x3ffb2720 0x400d3d48:0x3ffb2760 0x400d3f3d:0x3ffb27b0 0x400d3c63:0x3ffb27d0 0x400d26e5:0x3ffb27f0 0x400d531a:0x3ffb2820
13:14:36.110 ->
13:14:36.110 ->
13:14:36.110 ->
13:14:36.110 ->
13:14:36.110 -> ELF file SHA256: 0000000000000000
13:14:36.110 ->
13:14:36.110 -> Rebooting...
13:14:36.110 -> ets Jul 29 2019 12:21:46
13:14:36.110 ->
13:14:36.110 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
13:14:36.110 -> configsip: 271414342, SPIWP:0xee
13:14:36.110 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
13:14:36.110 -> mode:DIO, clock div:1
13:14:36.110 -> load:0x3fff0030,len:1184
13:14:36.110 -> load:0x40078000,len:13160
13:14:36.110 -> load:0x40080400,len:3036
13:14:36.110 -> entry 0x400805e4
If I comment out all NeoPixel code, everything works perfectly (Wifi and I2C scanning).
If I download and use the binary factory reset file without compiling the sketch, everything works (even the NeoPixel color change)
Does anyone have an idea to resolve my problem ?
Feather ESP32 V2 Neopixel not working, even factory reset
- jromang
- adafruit_support_carter
Re: Feather ESP32 V2 Neopixel not working, even factory reset
Try updating NeoPixel library to latest release. Probably related to this:
https://github.com/adafruit/Adafruit_NeoPixel/pull/330
