Hello there, I've recently gotten my self a Adafruit Prop-Maker FeatherWing and Adafruit Feather M4 Express and got it setup per the lightsaber guide. I got it working for a whole 3 days until suddenly I got an error stopping the project. Going online I was able to find out what the flashing Neopixel on the board meant. Hooked it to the computer using the Mu Editor and ran serial to find this error.
File "code.py", line 60, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
The code is from
https://learn.adafruit.com/lightsaber-f ... g/software and line 60 is
i2c = busio.I2C(board.SCL, board.SDA)
I re-applied my solder on both board headers to see if maybe something happened to break something when I was testing, however I've had no luck. I've tested the feather m4 with some other applications and it appears to be working fine but maybe the FeatherWing went bad? I was only testing it with a 144 neo pixels strip, speaker, and RGB switch that all came with the project. Please let me know if there is anything I can try doing on the FeatherWing as this is my first experience with them.
