However after adding what seems to be all that is needed for it to be triggered(with no syntax issues) uploading the library to my feather m4 express has no effect/change whatsoever on my Neopixel animations; it just stays on the sparkle animation and never switches. If it makes a difference I have 1 sparkle animation being drawn with a comet animation drawing over the sparkles. I just want to make sure I didnt run into another bug in the library code
import random
from adafruit_led_animation.animation import Animation
__version__ = "0.0.0+auto.0"
__repo__ = "https://github.com/adafruit/Adafruit_CircuitPython_LED_Animation.git"
class Sparkle(Animation):
Sparkle animation of a single color.
:param pixel_object: The initialised LED object.
:param float speed: Animation speed in seconds, e.g. ``0.1``.
:param color: Animation color in ``(r, g, b)`` tuple, or ``0x000000`` hex format.
:param num_sparkles: Number of sparkles to generate per animation cycle.
:param mask: array to limit sparkles within range of the mask
# pylint: disable=too-many-arguments
def __init__(
self, pixel_object, speed, color, num_sparkles=1, name=None, mask=None
if len(pixel_object) < 2:
raise ValueError("Sparkle needs at least 2 pixels")
if mask:
self._mask = mask
else:
self._mask = []
if len(self._mask) >= len(pixel_object):
raise ValueError("Sparkle mask should be smaller than number pixel array")
self._half_color = color
self._dim_color = color
self._sparkle_color = color
self._num_sparkles = num_sparkles
self._num_pixels = len(pixel_object)
self._pixels = []
#self.add_cycle_complete_receiver(animation, callback) #ignore
super().__init__(pixel_object, speed, color, name=name)
def on_cycle_complete(self):
self.cycle_count += 1
if self.cycle_count % self.notify_cycles == 0:
for callback in self._also_notify:
callback(self)
on_cycle_complete_supported=True
def _set_color(self, color):
half_color = tuple(color[rgb] // 4 for rgb in range(len(color)))
dim_color = tuple(color[rgb] // 10 for rgb in range(len(color)))
for pixel in range( # pylint: disable=consider-using-enumerate
len(self.pixel_object)
if self.pixel_object[pixel] == self._half_color:
self.pixel_object[pixel] = half_color
elif self.pixel_object[pixel] == self._dim_color:
self.pixel_object[pixel] = dim_color
self._half_color = half_color
self._dim_color = dim_color
def _random_in_mask(self):
if len(self._mask) == 0:
return random.randint(0, (len(self.pixel_object) - 1))
return self._mask[random.randint(0, (len(self._mask) - 1))]
def draw(self):
self._pixels = [self._random_in_mask() for _ in range(self._num_sparkles)]
for pixel in self._pixels:
self.pixel_object[pixel] = self._sparkle_color
if self.draw_count % len(self.pixel_object) == 0:
self.cycle_complete = True # no change
def after_draw(self):
self.show()
self.cycle_complete=True #no change
self.pixel_object[pixel % self._num_pixels] = self._half_color
if (pixel + 1) % self._num_pixels in self._mask:
self.pixel_object[(pixel + 1) % self._num_pixels] = self._dim_color
