I followed the procedure to
. select the board
. supply credentials
. select the appropriate USB COM entry
. follow the instructions on the Install Adafruit.IO WipperSnapper page
. loaded the firmware on the board - no errors reported
. depressed the RST button
. the LED near the RST button flashes some patterns and the blue LED at the other end of the board occasionally flashes
. followed the link to my adafruit.io page, but the board does not show up
I refreshed the page but the board does not appear. all that is shown is my old Funhouse board.
What do I need to do to get the new board to show up?
New Feather Huzzah ESP8266 does not appear in my boards
- chuck_untulis
- rooppoorali
Re: New Feather Huzzah ESP8266 does not appear in my boards
You can see the troubleshooting guideline: https://cdn-learn.adafruit.com/download ... sp8266.pdf
If this does not help, I think you should get your board checked by Adafruit team if the warranty is still valid.
- chuck_untulis
No errors reported in the installation process and adaftuit.io did not report an error it just doesn't show up. I am confused by the comments that WipperSnapper makes everything easier but in this case it appears easier but it just doesn't work and it reports no error. If there is a failure, then it should be reported. Saying to look in the documentation is not helpful.
- adafruit_support_carter
Were you following this guide?
https://learn.adafruit.com/adafruit-fea ... pper-setup
- chuck_untulis
No. I was following the directions after selecting my board which I thought would be sufficient. There was no indication at the time that I should go to the page you mentioned. It should have been specified early on in the process instead of "oh by the way". I will go and review that now.
I do not mean to be facetious, but many instructions are written by developers who already have a lot of domain knowledge. These "simple" instructions are confusing for people without that knowledge. I do not know if you have reviewers or just wait until a naive user discovers a problem and then has to do the detective work to accumulate enough knowledge to try to ask intelligent questions. The simple statement to "read the instructions" without some hints is not always helpful. If one of Adafruit's often stated goals is to help people learn...
- brubell
- Learn User Page
Hi Chuck,
if not, could you navigate to https://serialmonitor.dev/? Select 115200 as the baud rate and then select your board's serial port (should be the same as what you provided to the WipperSnapper web uploader)
if neither, I can load up an esp8266 and see if i can duplicate the issue from my end.
Adafruit.io WipperSnapper is still in beta - we're actively working on incorporating feedback into the platform and the firmware. The new device page, for instance, was added a few months ago to decrease confusion about the scattered installation pages. When a user experiences an issue during the beta period, we do our best to solve them, they're discussed with our development team (including me!) and then incorporated into AdafruitIO/WipperSnapper beta so the same issue isn't recurring across users.
Do you have Arduino IDE installed? Are you able to open the Serial Monitor and check the output from the ESP8266? If you are, could you paste it here?. the LED near the RST button flashes some patterns and the blue LED at the other end of the board occasionally flashes
Sorry that you're frustrated. We'll work on solving it in this thread.These "simple" instructions are confusing for people without that knowledge
- chuck_untulis
I just Uploaded the WipperSnapper code with no errors.
The https://serialmonitor.dev/ does not report an error when connected to the device nor does any text come out. Is there supposed to output? If so, then that should be stated. If not, then that should be stated. I am confused about what the result of the serial monitor should show?
Uploading the blink sketch from Arduino and I get:
Sketch uses 218194 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 17932 bytes (5%) of dynamic memory, leaving 309748 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.1
Serial port COM4
Connecting....
A fatal error occurred: This chip is ESP8266 not ESP32-S2. Wrong --chip argument?
That confirms that either the Uploader is wrong or the board selection and Instructions are wrong.
esptool.py v3.1
Serial port COM4
Connecting....
- chuck_untulis
Any chance of this being solved or at least acknowledged ... I am still in limbo?
Or do I abandon WipperSnapper again because it does not work as advertised?
- brubell
- Learn User Page
There _is_ supposed to be debugging output to help guide us through his issue. I'm not sure why it's not appearing.The https://serialmonitor.dev/ does not report an error when connected to the device nor does any text come out. Is there supposed to output? If so, then that should be stated. If not, then that should be stated. I am confused about what the result of the serial monitor should show?
Could you:
Upload wippersnapper to the ESP8266 using the Web Uploader
Press the RESET button on the ESP8266.
Open Arduino IDE
Select your Feather ESP8266 from Arduino->Tools->Port->select the port
Open the serial monitor, and make sure it's set to 115200 baud.
If there is debug text in the serial monitor, please copy it here. If not, let me know. This is data we'll need to know in order to reproduce and fix the issue.
I'm currently wrapping up work on the Pixel API. I am going to work on the pending issues labeled `bug` on the WipperSnapper repository within the next week.Any chance of this being solved or at least acknowledged ... I am still in limbo?
You can subscribe to track this ESP8266 issue here: https://github.com/adafruit/Adafruit_Wi ... issues/334
This is unrelated to the core issue, but, you need to select the Feather ESP8266 Huzzah from the Arduino IDE (Tools->Board->Make sure ESP8266 is selected)
esptool.py v3.1
Serial port COM4
Connecting....
- chuck_untulis
I will go through the process again, but I do not expect any different results because I have been through it a number of times. You said you were going to try using your ESP8266. I assume you have not done that?
- Tejas001
I'm having the same problem. WipperSnapper was installed on my ESP8266 successfully but it's stuck connecting to WiFi. I'm aware that the instruction says to not have any space in SSID (how to enter SSIDs with spaces in them?), but the board is detecting the SSID correctly as you can see in the serial log from Arduino IDE below,
It is stuck in a loop and isn't showing up in devices section in my profile. My WiFi is 2.45GHz only. I have tried resetting and reconnecting the board to USB port with no change. Any help is highly appreciated!
- chuck_untulis
I posted a response earlier but it seems to have disappeared???
Basically I ran the experiment again wit the same results:
No error messages
Device still has not appeared on my devices page
Serial monitor connected to COM4 at 115200 but shows no output
Arduino connected to the appropriate COM port with speed set to 115200 but no output
No error messages
- chuck_untulis
I tried yet again and I finally received what might be useful information.
Device RST depressed.
I started serialmonitor.dev selecting the ESP8266 on COM4 and there was no output
I would suggest adding a note to unplug other USB COM devices because
when I also had a Trellis plugged in, I did not get any output from the Arduino Serial Monitor)
I started Arduino>Serial Monitor with only the ESP8266 plugged in and finally have the following output:
I deleted the rest because it seemed like it was another repeat of the previous information.
Where can I find information on Exception 28? If I had that information I might be able to help solve the problem.
ESP8266 does not appear on my devices page.
Is there a problem with my old aio_key? If so, how do I get a replacement?
Is there a problem with my old key? If so, how do I get a replacement?
Wippersnapper Firmware Uploader loaded.
Connecting...
Connected successfully.
Try hard reset.
Chip type ESP8266
Connected to ESP8266
MAC Address: 5C:CF:7F:3A:2E:CE
Uploading stub...
Running stub...
Stub is now running...
Detecting Flash Size
FlashId: 0x1640E0
Flash Manufacturer: e0
Flash Device: 4016
Auto-detected Flash size: 4MB
Attempting to change baud rate to 921600...
Changed baud rate to 921600
Fetching latest firmware...
Unzipping firmware bundle...
Flashing with settings:
"files": [
"filename": "secrets.json"
"rootFolder": "files",
"offset": 2097152,
"chip": "esp8266",
"fileSystemSize": 65536,
"blockSize": 8192,
"structure": {
"0": "wippersnapper.feather_esp8266.littlefs.1.0.0-beta.51.bin"
Unzipping wippersnapper.feather_esp8266.littlefs.1.0.0-beta.51.bin...
Image header, Magic=0xE9, FlashMode=0x00, FlashSizeFreq=0x40
Writing data with filesize: 388304
Erase size 388304, blocks 24, block size 0x4000, offset 0x0000, encrypted no
4% (16384/388304)...
8% (32768/388304)...
12% (49152/388304)...
16% (65536/388304)...
21% (81920/388304)...
25% (98304/388304)...
29% (114688/388304)...
33% (131072/388304)...
37% (147456/388304)...
42% (163840/388304)...
46% (180224/388304)...
50% (196608/388304)...
54% (212992/388304)...
59% (229376/388304)...
63% (245760/388304)...
67% (262144/388304)...
71% (278528/388304)...
75% (294912/388304)...
80% (311296/388304)...
84% (327680/388304)...
88% (344064/388304)...
92% (360448/388304)...
97% (376832/388304)...
100% (388304/388304)...
Took 5769ms to write 388304 bytes
Erase size 0, blocks 0, block size 0x4000, offset 0x0000, encrypted no
Image header, Magic=0x01, FlashMode=0x00, FlashSizeFreq=0x00
Writing data with filesize: 65536
Erase size 65536, blocks 4, block size 0x4000, offset 0x200000, encrypted no
25% (16384/65536)...
50% (32768/65536)...
75% (49152/65536)...
100% (65536/65536)...
Took 890ms to write 65536 bytes
To run the new firmware, please reset your device.
23:08:59.146 -> FSM_NET_ESTABLISH_MQTT
23:09:02.143 ->
23:09:02.143 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
23:09:02.143 ->
23:09:02.143 -> Exception (28):
23:09:02.143 -> epc1=0x40220cde epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
23:09:02.143 ->
23:09:02.143 -> >>>stack>>>
23:09:02.143 ->
23:09:02.143 -> ctx: cont
23:09:02.143 -> sp: 3ffffd10 end: 3fffffc0 offset: 0190
23:09:02.143 -> 3ffffea0: 40106255 0049ebd0 3fff206c 00000000
23:09:02.143 -> 3ffffeb0: 3fff0ab0 3fff206c 0000012c 4020d2ba
23:09:02.143 -> 3ffffec0: 000000ff 3fff206c 3fff2f5c 4020d1da
23:09:02.143 -> 3ffffed0: 40216c3d 0000012c 00000014 40216c32
23:09:02.143 -> 3ffffee0: 00000005 0000012c 00000000 00000014
23:09:02.188 -> 3ffffef0: 00000005 3fff191c 3fff0f18 40208581
23:09:02.188 -> 3fffff00: 402146e8 3ffeb1f0 3fff1c84 40214954
23:09:02.188 -> 3fffff10: 00000001 00000016 3fff1c84 40214a38
23:09:02.188 -> 3fffff20: 0000007f 0000003a 3fff1a1c 00000000
23:09:02.188 -> 3fffff30: 3fff191c 3fff0f18 3fff1c84 402088db
23:09:02.188 -> 3fffff40: 0000002e 000000ce ffffffff 00000001
23:09:02.188 -> 3fffff50: 433a4335 46373a46 3a41333a 433a4532
23:09:02.188 -> 3fffff60: 00000045 00000001 3fff1c84 40214794
23:09:02.188 -> 3fffff70: 00000000 00000000 3fff0f18 3fff1d10
23:09:02.188 -> 3fffff80: 0001c200 0000001c 00000000 3fff1d10
23:09:02.235 -> 3fffff90: 3fffdad0 00000000 3fff0f18 40207189
23:09:02.235 -> 3fffffa0: feefeffe feefeffe 3fff1cfc 4021586c
23:09:02.235 -> 3fffffb0: feefeffe feefeffe 3ffe8600 401013f9
23:09:02.235 -> <<<stack<<<
23:09:02.235 ->
23:09:02.235 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
23:09:02.235 ->
23:09:02.235 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
23:09:02.235 ->
23:09:02.235 -> load 0x4010f000, len 3460, room 16
23:09:02.282 -> tail 4
23:09:02.282 -> chksum 0xcc
23:09:02.282 -> load 0x3fff20b8, len 40, room 4
23:09:02.282 -> chksum 0xc9
23:09:02.282 -> csum 0xc9
23:09:02.282 -> v0005ecd0
23:09:02.282 -> ~ld
23:09:02.328 -> Adafruit.io WipperSnapper
23:09:02.328 -> -------Device Information-------
23:09:02.328 -> Firmware Version: 1.0.0-beta.51
23:09:02.328 -> Board ID: feather-esp8266
deleted user, network and MAC address info because I received an invalid form
23:09:02.328 -> -------------------------------
23:09:02.328 -> Subscribing to MQTT topics...
23:09:02.328 -> Running Network FSM...
23:09:05.320 -> Attempting to connect to WiFi...
23:09:06.019 -> CONNECTING
23:09:18.794 -> FSM_NET_ESTABLISH_MQTT
23:09:21.795 ->
23:09:21.795 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
23:09:21.795 ->
23:09:21.795 -> Exception (28):
23:09:21.795 -> epc1=0x40220cde epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
23:09:21.795 ->
23:09:21.795 -> >>>stack>>>
23:09:21.795 ->
23:09:21.795 -> ctx: cont
23:09:21.795 -> sp: 3ffffd10 end: 3fffffc0 offset: 0190
23:09:21.795 -> 3ffffea0: 40106255 005cf793 3fff206c 00000000
23:09:21.795 -> 3ffffeb0: 3fff0ab0 3fff206c 0000012c 4020d2ba
23:09:21.795 -> 3ffffec0: 000000ff 3fff206c 3fff2f5c 4020d1da
23:09:21.843 -> 3ffffed0: 40216c3d 0000012c 00000014 40216c32
23:09:21.843 -> 3ffffee0: 00000005 0000012c 00000000 00000014
23:09:21.843 -> 3ffffef0: 00000005 3fff191c 3fff0f18 40208581
23:09:21.843 -> 3fffff00: 402146e8 3ffeb1f0 3fff1c84 40214954
23:09:21.843 -> 3fffff10: 00000001 00000016 3fff1c84 40214a38
23:09:21.843 -> 3fffff20: 0000007f 0000003a 3fff1a1c 00000000
23:09:21.843 -> 3fffff30: 3fff191c 3fff0f18 3fff1c84 402088db
23:09:21.843 -> 3fffff40: 0000002e 000000ce ffffffff 00000001
23:09:21.843 -> 3fffff50: 433a4335 46373a46 3a41333a 433a4532
23:09:21.843 -> 3fffff60: 00000045 00000001 3fff1c84 40214794
23:09:21.843 -> 3fffff70: 00000000 00000000 3fff0f18 3fff1d10
23:09:21.889 -> 3fffff80: 0001c200 0000001c 00000000 3fff1d10
23:09:21.889 -> 3fffff90: 3fffdad0 00000000 3fff0f18 40207189
23:09:21.889 -> 3fffffa0: feefeffe feefeffe 3fff1cfc 4021586c
23:09:21.889 -> 3fffffb0: feefeffe feefeffe 3ffe8600 401013f9
23:09:21.889 -> <<<stack<<<
23:09:21.889 ->
23:09:21.889 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
23:09:21.889 ->
23:09:21.889 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
23:09:21.889 ->
23:09:21.889 -> load 0x4010f000, len 3460, room 16
23:09:21.935 -> tail 4
23:09:21.935 -> chksum 0xcc
23:09:21.935 -> load 0x3fff20b8, len 40, room 4
23:09:21.935 -> chksum 0xc9
23:09:21.935 -> csum 0xc9
23:09:21.935 -> v0005ecd0
23:09:21.935 -> ~ld
23:09:21.981 -> Adafruit.io WipperSnapper
23:09:21.981 -> -------Device Information-------
23:09:21.981 -> Firmware Version: 1.0.0-beta.51
23:09:21.981 -> Board ID: feather-esp8266
23:09:21.981 -> Adafruit.io User: chuck.untulis
23:09:21.981 -> WiFi Network: qA573d92
23:09:21.981 -> MAC Address: 5C:CF:7F:3A:2E:CE
23:09:21.981 -> -------------------------------
23:09:21.981 -> Subscribing to MQTT topics...
23:09:21.981 -> Running Network FSM...
23:09:24.977 -> Attempting to connect to WiFi...
23:09:25.677 -> CONNECTING
23:09:35.488 -> ...
Connecting...
Try hard reset.
Chip type ESP8266
Uploading stub...
Running stub...
FlashId: 0x1640E0
Flash Device: 4016
"files": [
"offset": 2097152,
"chip": "esp8266",
"blockSize": 8192,
"structure": {
23:09:02.143 ->
23:09:02.143 ->
23:09:02.143 ->
23:09:02.143 ->
23:09:02.235 ->
23:09:02.235 ->
23:09:02.235 ->
23:09:02.282 -> ~ld
23:09:02.328 -> Adafruit.io User: chuck.untulis
23:09:02.328 -> WiFi Network: qA573d92
23:09:02.328 -> MAC Address: 5C:CF:7F:3A:2E:CE
23:09:21.795 ->
23:09:21.795 ->
23:09:21.795 ->
23:09:21.795 ->
23:09:21.889 ->
23:09:21.889 ->
23:09:21.889 ->
23:09:21.935 -> ~ld
23:09:35.488 -> ...
- adafruit2
you can regen IO key pretty easily but probably better to just go with an ESP32 instead of an 8266 which is at this point kinda ancient. do you have an ESP32 board?
- chuck_untulis
I don't understand that if it is ancient and it does not seem to be supported, why have it on the page?
At the very least there should be a pointer to another similar board that has a better chance of being supported.
This whole experience further denigrates my opinion of Whippersnapper and Adafruit.
Why try to sell Whippersnapper to users if it is in perpetual Beta and support is lacking?
