Received my order today (Invoice: 2926226 ), and I tried connecting one of the ESP32-S3 QT Pys up to my computer to load the latest Circuitpython build. I got an error message from Windows saying "USB device not recognized", and it doesn't show up as a COM port. No status LEDs either; I tried resetting several times but still nothing.
I tried the other Qt Py (I ordered two), and this one did show up connected as a COM Port and flashed a rainbow cycle pattern on its LED, but it didn't show up as a CIRCUITPY drive. I followed the steps on https://learn.adafruit.com/adafruit-qt- ... tory-reset and tried the ESP web flasher, but I kept getting the error message "Couldn't sync to ESP. Try resetting." (I've copied the utility's output below.)
I'm pretty sure I"m using a good data cable because I've used it to upload firmware to, and generally upload code to two other Feather boards (an ESP32-S3 TFT Feather and regular ESP32-S3 Feather), and I use the same cable to send commands to an ESP32-S2 based laser cutter.
I suspect the first QT Py that doesn't connect at all has a manufacturing defect (see images below- the chip looks visibly skewed, but I'm not sure about the other one. Are there any further steps I should take to troubleshoot, or should I return?
(ESP Web Flasher output below: attempted to connect a few times...)
ESP Web Flasher loaded.
Connecting...
Connected successfully.
Try hard reset.
[Object.debug:187] Finished read loop
Error: Couldn't sync to ESP. Try resetting.
Connecting...
Try hard reset.
Connecting...
Try hard reset.
Connecting...
Try hard reset.
Connecting...
Try hard reset.
Defective QT Pys (?)
- rmvsintheta
- 20220927_113258.jpg (217.13 KiB) Viewed 72 times
- 20220927_113255.jpg (212.74 KiB) Viewed 72 times
- 20220927_113325.jpg (254.81 KiB) Viewed 72 times
- Franklin97355
Re: Defective QT Pys (?)
If one S3 QTPY works and the other one does not Contact [email protected] with a link to this thread and they will get you a replacement.
- rmvsintheta
Thanks for the response! I guess my problem is both seem to be defective in different ways, and I'd rather see if there are steps I should take for the other semi-unresponsive board before I send it back. I'd rather not take two trips to the post office if I can help it!
- adafruit2
what version of windows are you running
when you hold down the BOOT button and then plug into usb, does anything appear in device manager
- adafruit_support_carter
This is expected behavior. The CircuitPython firmware will need to be loaded first.I tried the other Qt Py (I ordered two), and this one did show up connected as a COM Port and flashed a rainbow cycle pattern on its LED, but it didn't show up as a CIRCUITPY drive.
Try again but first manually put the board in bootloader mode:I followed the steps on https://learn.adafruit.com/adafruit-qt- ... tory-reset and tried the ESP web flasher, but I kept getting the error message "Couldn't sync to ESP. Try resetting." (I've copied the utility's output below.)
https://learn.adafruit.com/adafruit-qt- ... de-3106832
- rmvsintheta
Thanks adafruit2 and adafruit_support_carter!
@adafruit2 I did manage to get the board working by holding down the BOOT button and plugging the board in- the ESP web flasher worked perfectly from there, and I managed to load in circuitpython and run some test code/stemma breakouts without issue. Just for reference I am running Windows 11.
@adafruit_support_carter Didn't see your post until after the problem was solved, but in retrospect I think I accidentally skipped the bootloader mode step- will keep in mind for the future.
Just to be sure, I tried all of the above with the other (skewed-chip) board but no dice- will go through with returning that one.
Thanks again!
Thanks again!
Cool. Glad the other one works. Yep, seems like just a missed step in the install. No worries, just happy that one is working as expected.
Yep - email [email protected] to get the other one replaced.
