Hi folks,
I wanted to get some guidance on a product to buy. I want to build a custom MIDI controller from scratch, the first revision needs to have 6 rotating pots, 2 slider pots, and 2 buttons. Are there any boards that I could wire those up to? I have expert level coding experience, and next to no electronics experience. Does anyone have any tips on what product to buy?
I have added the following non-circuit items to my cart:
Thank you in advance.
Custom Midi Controller
- glitchington
- Screen Shot 2022-09-28 at 8.57.04 AM.png (298.91 KiB) Viewed 39 times
- johnpark
Re: Custom Midi Controller
Hey awesome, I love making MIDI controllers. They key thing here is going to be reading the eight analog inputs. A lot of microcontroller dev boards have only 4-6 ADC (analog to digital converter) pins. So you can either get a board with loads of them, such as the Grand Central https://www.adafruit.com/product/4064 which has 15 ADC pins, or you can add a dedicated ADC breakout such as the Seesaw https://www.adafruit.com/product/5233 which gives you 9 10-bit ADC pins to use and you can have it talk to your dev board (such as Feather RP2040) over I2C using the convenient STEMMA QT cable.
