MPM3610 Buck Converter Defective
Spitfire2865
Post by Spitfire2865 »
Hello
Ive now bought two of this board and both have been defective.
The first, wired correctly, gives ~1V output for 12V input.
The second, wired on a breadboard for clearer planning, gives ~9V output for 12V input.
This is intended to power a 5V servo trigger, so 5V is critical.
Im using a basic 12V 2A transformer.
On both boards, I was getting 12V on the input but very much not 5V on the output.
Whats wrong here?
adafruit_support_carter
Re: MPM3610 Buck Converter Defective
Can you post a photo of your setup showing how everything is connected so we can check for any obvious hardware issues.
Spitfire2865
Ok its a bit hard to see because I was trying to go compact.
+ and - are 12V and ground respectively.
I have a jumper wire from - to J1, a jumper from + to J3, and my output is on J2 and -.
The buck converter is fully isolated from the board and is only connected via pins on I1-I4.
When I feed 12V into it, its giving me 9V out.
The first buck Ive since desoldered as it was done in place on the control board rather than a separate breadboard.
And heres a backside pic showing that Im not bridging any contacts that shouldnt be.
Thanks. That looks generally OK.
And just to verify what you're seeing. If you power up the setup shown and measure the voltage on the headers pins directly on the MPM3610 breakout - you see the expected 12V on the Vin pin, but 9V on the 5V pin?
Spitfire2865
That is correct.
Double check the soldering on these pins:
There's a fair amount of the pad visible. Can't tell from the photo angle. Make sure the soldering is good on both the pin and the pad (wetted out adequately).
Also, the other board gave very different output:
How was that one being used?
Spitfire2865
I know the soldering on the board is sufficient as Ive traced all continuity paths before I even plugged it in. And a dry joint wouldnt result in 4V over what is expected. I had continuity everywhere I expected it and nowhere I didnt want it.
The first board was soldered with the ground and 5V pins directly to the power input of a control board using header pins, with power coming in from wires soldered to Vin and the exposed Gnd pin above the board.
After disassembling that, I tried the buck without the control board and was only getting a max of about 1V out of it.
adafruit2
Post by adafruit2 »
can you tell us how you are measuring, is it with a scope or multimeter and if its a meter is it handheld? the resistor values are correct and we do test the voltage out - it makes us think that something else is weird with your setup.
Spitfire2865
Im measuring it with a portable multimeter on the output. This meter has been accurate before. It gives me a clean 12V reading on the input side and a clean 9V reading on the output.
I dont know what else it could be since its simply a one input one output circuit.
adafruit2
Post by adafruit2 »
yeah like you said theres... just not a lot that can go wrong here. what is the power supply providing 12V?
we can replace these two BUT when you get the replacements, test them in isolation, not soldered into your circuit. a solderless breadboard is best.
Spitfire2865
Its just a 12V 2A power pack Ive used before for projects. Your standard US outlet mounted brick with a DC barrel jack output.
Id gladly test replacements in isolation.
Spitfire2865
Ok this is so strange. I just plugged it back in as it was and now the output is 12V. That makes no sense.
Spitfire2865
Ok who can I contact regarding replacements?
adafruit2
Post by adafruit2 »
you can email support@adafruit for 2 pcs replacement
Spitfire2865
Well. Ive received the replacements and...
Still getting inconsistent results.
Ive simplified my board wiring this time to guarantee things dont go wrong.
With buck pressed onto pins temporarily.
The voltage jumps around a lot. Usually sits between 5-10V but sometimes I get nothing out of it.
Im lost and about to go with a different buck alltogether because this is tiring.
