hello I have recently bought 3 of these devices from a supplier which had just received a new batch of these.
All 3 do not work as expected. I had ordered in the past about 8 months ago and the MCP worked fine, I attach a picture. The left most one (marked A) works ok and was bought some time before. The right most one (marked B) does not work. I have not changed my application at all.
This is a MIDI to CV convertor. I cannot calibrate the new issue DAC at all.
The newer model on the right doesn't work. All 3 of these new issued devices (marked B) are the same. What has changed, or are all these new batch faulty. New packaging image attached.
thanks
Alan Watkins
MCP4728 issues with new release
- adafruit_support_carter
Re: MCP4728 issues with new release
You may have a rev with a MCP4728A4 instead of the MCP4728. See note at bottom of product page:
https://www.adafruit.com/product/4470
One result of this is the change in default I2C address, which would require a code change to specify.
For the Arduino library, pass in the address in the call to begin(), ex:
For the CircuitPython library, specify the address when creating the instance, ex:
mcp.begin(0x64); // for MCP4728A4 (default address 0x64)
mcp4728 = adafruit_mcp4728.MCP4728(i2c, adafruit_mcp4728.MCP4728A4_DEFAULT_ADDRESS)
- Mindburner
Thanks for the reply. I looked at the IC closely and it is indeed MCP4728A4.
I have an old piece of code an I was unsure of how to change the IC2 address in it. The development of this code seems to have since stopped.
Would anyone be able to point me to what amendments I need to add to make this work.
thanks
thanks
// CONFIGURATION =============================================================
// Pin 1 is reserved for MIDI RX.
// Pins A4 and A5 are reserved for the DAC I2C communication.
const byte MODE_BUTTON = A0; // Main button pin
const byte MODE_LEDS[] = { A1, A2, A3 }; // RGB LED pins for current mode display
const bool MODE_LEDS_PWM = true; // Set to FALSE to disable SoftPWM and adjust RGB brightness with resistors only
const byte GATES[] { 3, 4, 5, 6 }; // Gate 1-4 pins
const byte GATE_OR = 7; // Auxiliary gate pin, high when at least one gate is high
const byte GATES_LEDS[] { 8, 9, 10, 11 }; // LEDs pins for gates display
const byte GATE_OR_LED = 12; // Auxiliary gate pin, high when at least one gate is high
const byte NOTE_ON_LED = 13; // LED pin for showing note-on signals
const unsigned int GATE_RETRIG_MS = 40; // Time between two consecutive gates in ms, to retrig envelopes
const byte PITCH_BEND_SEMITONES = 2; // Picth-bend range in semitones
const byte SPLIT_MIDI_OCTAVE = 4; // Defines on which MIDI octave the keyboard will be split for poly+mono mode
const int LOWEST_MIDI_OCTAVE = 2; // CV out range is four octaves max, this defines which MIDI octave will be mapped to zero CV
const unsigned long BUTTON_LOCK_LONG_PRESS_MS = 500; // Button long-press duration to lock currently help polyphonic voices
const unsigned long BUTTON_DEBOUNCE_DELAY = 50; // Debounce delay for the button
const unsigned long LED_MODE_LOCK_DURATION_MS = 500; // How long the mode LED should be kept off to signal voices lock
const unsigned long LED_MIN_DURATION_MS = 50; // Minimum "on" duration for LEDs visibility
// DEBUGGING =================================================================
const bool DEBUG = false; // FALSE to disable debug messages on serial port
// By enabling debugging, the hardware serial port will be used for both debug
// messages and MIDI messages. Therefore, it's required to use a PC bridge to
// test hardware MIDI devices, like ttymidi: http://www.varal.org/ttymidi/
const bool DEBUG_WITH_TTYMIDI = false; // TRUE to use ttymidi bridge and print messages on serial
// Notes about debugging with ttymidi:
// - run: ttymidi -s /dev/ttyUSB0 -b 9600 -v
// - then connect the hardware MIDI device output to ttymidi input
#include <EEPROM.h>
#include <MIDI.h>
#include <SoftPWM.h>
#include <Wire.h>
#include <Adafruit_MCP4728.h>
#include "lib/Button.cpp"
#include "lib/Led.cpp"
#include "lib/MCP4728.cpp"
#include "lib/MultiPointMap.cpp"
#include "mono.cpp"
#include "poly.cpp"
#define N 4 // Number of voices, each with its own CV/gate signals
#define MODE_POLY 0 // 4x polyphony with priority to last
#define MODE_POLY_FIRST 1 // 4x polyphony with priority to first
#define MODE_POLY_MONO 2 // Keyboard split with 3x polyphony on lower keys, monophony on higher keys
#define MODE_MONO_POLY 3 // Keyboard split with monophony on lower key, 3x polyphony on higher keys
#define MODE_MONO 4 // 4x monophony on MIDI channels 1-4
#define MODE_POLY_RGB 0x330000 // Red
#define MODE_POLY_FIRST_RGB 0x003300 // Green
#define MODE_POLY_MONO_RGB 0x0000CC // Blue
#define MODE_MONO_POLY_RGB 0x3300CC // Pink
#define MODE_MONO_RGB 0x009966 // Teal
#define CALIBRATION_RGB 0x3333CC // White
Button modeButton;
MCP4728 dac;
MultiPointMap calibration[4];
Led gateLed[N];
Led gateOrLed;
Led noteOnLed;
NoteStack mono[N];
VoiceAllocator poly;
byte mode = MODE_POLY;
byte voiceMidiNote[N]; // Current MIDI note for each voice
bool voiceActive[N]; // Current activation state for each voice
unsigned long voiceRetrigTime[N]; // Time the retrig interval started, zero if retrig is not occurring
bool voiceLocked[N]; // TRUE if the voice is currently locked
unsigned long voiceLockLedTime = 0; // Time the mode LED has been turned off to signal lock
int pitchBend; // Pitch-bend value (all voices in poly modes, monophonic voice only in split modes)
bool outputFlag; // TRUE if it's necessary to update the outputs
bool calibrating = false; // TRUE if currently running the calibration process
byte calibratingVoice; // Voice currently being calibrated
byte calibratingInterval; // Calibration point index for the current voice
int calibratingAddress; // EEPROM address to store the current calibration
const int MODE_EEPROM_ADDRESS = 0;
const int DAC_CALIBRATION_EEPROM_ADDRESS = 100;
#define MIDI_NOTE_TO_CV_FACTOR 83.333333 // 1000/12, i.e. 1000mV per octave
#define MIDI_PITCHBEND_MAX 8191 // Maximum value for pitch-bending, as given by MIDI.h library
const char NOTE_NAMES[12][3] = { "C", "C#", "D", "D#", "E", "F", "F#", "G", "G#", "A", "A#", "B" };
// MIDI custom settings
// https://github.com/FortySevenEffects/arduino_midi_library/wiki/Using-custom-Settings
struct MIDISettings : public midi::DefaultSettings {
static const long BaudRate = 31250;
static const bool UseRunningStatus = false;
static const bool Use1ByteParsing = false;
MIDI_CREATE_CUSTOM_INSTANCE(HardwareSerial, Serial, MIDI, MIDISettings);
// Init MIDI
MIDI.begin(MIDI_CHANNEL_OMNI); // Listen to all channels
MIDI.turnThruOff(); // Required after begin()
// Debugging
if (DEBUG || DEBUG_WITH_TTYMIDI) {
Serial.begin(9600);
if (DEBUG) debug("MIDI 4+1 - ");
// Setup I/O
modeButton.init(MODE_BUTTON, BUTTON_DEBOUNCE_DELAY, true, true);
pinMode(GATE_OR, OUTPUT);
gateOrLed.init(GATE_OR_LED, LED_MIN_DURATION_MS);
noteOnLed.init(NOTE_ON_LED, LED_MIN_DURATION_MS);
for (byte i = 0; i < N; i++) {
pinMode(GATES[i], OUTPUT);
gateLed[i].init(GATES_LEDS[i]);
// Setup mode RGB LED
if (MODE_LEDS_PWM) {
SoftPWMBegin(); // Software PWM for the mode RGB LED
} else {
pinMode(MODE_LEDS[0], OUTPUT);
pinMode(MODE_LEDS[1], OUTPUT);
pinMode(MODE_LEDS[2], OUTPUT);
// Init I2C communication and DAC
Wire.begin();
Wire.setClock(400000); // Fast mode
dac.init(Wire, 0);
dac.selectVref(MCP4728::VREF::INTERNAL_2_8V, MCP4728::VREF::INTERNAL_2_8V, MCP4728::VREF::INTERNAL_2_8V, MCP4728::VREF::INTERNAL_2_8V);
dac.selectPowerDown(MCP4728::PWR_DOWN::NORMAL, MCP4728::PWR_DOWN::NORMAL, MCP4728::PWR_DOWN::NORMAL, MCP4728::PWR_DOWN::NORMAL);
dac.selectGain(MCP4728::GAIN::X2, MCP4728::GAIN::X2, MCP4728::GAIN::X2, MCP4728::GAIN::X2);
// Load DACs calibration
int calibrationAddress = DAC_CALIBRATION_EEPROM_ADDRESS;
for (byte i = 0; i < 4; i++) {
calibration[i].init(4000);
calibrationAddress += calibration[i].load(calibrationAddress);
// If mode button is pressed on boot, start calibration process
delay(100);
if (modeButton.readOnce()) {
setupCalibration();
} else {
setupMain();
void setupMain() {
// Init voice allocators
poly.init();
mono[i].init();
voiceMidiNote[i] = 12; // Init voices to C0
bootAnimation();
// Set minimum "on" duration on gate LEDs
gateLed[i].setMinDurationMs(LED_MIN_DURATION_MS);
// Init mode from permanent storage
byte initialMode = EEPROM.read(MODE_EEPROM_ADDRESS) % 5;
setMode(initialMode);
// MIDI callbacks
MIDI.setHandleNoteOn(handleNoteOn);
MIDI.setHandleNoteOff(handleNoteOff);
MIDI.setHandlePitchBend(handlePitchBend);
void setupCalibration() {
// Start calibration process
calibrating = true;
calibratingVoice = 0;
calibratingInterval = 0;
calibratingAddress = DAC_CALIBRATION_EEPROM_ADDRESS;
setModeLedColor(CALIBRATION_RGB);
// MIDI callback
MIDI.setHandleNoteOn(handleCalibrationOffset);
MIDI.read();
if (calibrating) {
loopCalibration();
} else {
loopMain();
// Update LEDs
gateOrLed.loop();
noteOnLed.loop();
for (byte i = 0; i < N; i++) gateLed[i].loop();
void loopMain() {
// Check if retrig intervals are over
if (voiceRetrigTime[i] > 0) {
if (voiceRetrigTime[i] + GATE_RETRIG_MS < millis()) {
voiceRetrigTime[i] = 0;
outputFlag = true;
// Update outputs if necessary
if (outputFlag) {
output();
outputFlag = false;
// Check for mode button presses
byte modeButtonPress = modeButton.readShortOrLongPressOnce(BUTTON_LOCK_LONG_PRESS_MS);
if (modeButtonPress == 1) {
setMode((mode + 1) % 5); // Short-press: cycle through modes
} else if (modeButtonPress == 2) {
voicesLock(); // Long-press: lock voices
// Re-set mode LED if necessary
if (voiceLockLedTime > 0 && voiceLockLedTime + LED_MODE_LOCK_DURATION_MS < millis()) {
setModeLed();
void loopCalibration() {
// Button advance through calibration points and voices
calibratingInterval++;
if (calibratingInterval == calibration[calibratingVoice].size()) {
// Voice calibration completed, save and advance to next voice
calibratingAddress += calibration[calibratingVoice].save(calibratingAddress);
calibratingVoice++;
// Calibration completed?
if (calibratingVoice == N || calibratingVoice == 4) {
for (byte i = 0; i < N; i++) gateLed[i].off();
setModeLedColor(0x000000);
delay(1000);
setupMain();
return;
// Show which voice is currently being calibrated
gateLed[i].set(i == calibratingVoice);
if (millis() % 50 == 0) {
// Update DAC values
unsigned int size = calibration[calibratingVoice].size();
unsigned int step = calibration[calibratingVoice].getStep();
unsigned int value = step * (calibratingInterval + 1);
dac.analogWrite(
calibration[0].map(calibratingVoice == 0 ? value : (calibratingVoice > 0 ? step * size : 0)),
calibration[1].map(calibratingVoice == 1 ? value : (calibratingVoice > 1 ? step * size : 0)),
calibration[2].map(calibratingVoice == 2 ? value : (calibratingVoice > 2 ? step * size : 0)),
calibration[3].map(calibratingVoice == 3 ? value : (calibratingVoice > 3 ? step * size : 0))
// Update gates
digitalWrite(GATES[i], calibratingVoice == i);
void setMode(byte m) {
// Setup polyphonic allocator
mode = m;
switch (mode) {
case MODE_POLY:
poly.setMode(VoiceAllocator::Mode::LAST);
poly.setSize(N);
break;
case MODE_POLY_FIRST:
poly.setMode(VoiceAllocator::Mode::FIRST);
poly.setSize(N);
break;
case MODE_POLY_MONO:
case MODE_MONO_POLY:
poly.setSize(N - 1);
break;
// Mode selection on permanent storage
EEPROM.update(MODE_EEPROM_ADDRESS, mode);
setModeLed();
reset();
void voicesLock() {
// If any voice is locked, unlock it
bool unlocked = false;
if (voiceLocked[i]) {
voiceLocked[i] = false;
voiceActive[i] = false;
outputFlag = true;
unlocked = true;
if (mode != MODE_MONO) {
// Lock currently held polyphonic voices
if (!unlocked) {
if (voiceActive[i] && !isNoteForMonophony(voiceMidiNote[i])) {
voiceLocked[i] = true;
if (DEBUG) debugVoices();
// Turn off the mode LED to signal (un)locking
voiceLockLedTime = millis();
SoftPWMSet(MODE_LEDS[0], 0);
SoftPWMSet(MODE_LEDS[1], 0);
SoftPWMSet(MODE_LEDS[2], 0);
} else {
digitalWrite(MODE_LEDS[0], LOW);
digitalWrite(MODE_LEDS[1], LOW);
digitalWrite(MODE_LEDS[2], LOW);
void reset() {
// Reset gates; CVs don't need reset, they'll keep the last note value and that's fine
digitalWrite(GATES[i], LOW);
gateLed[i].off();
digitalWrite(GATE_OR, LOW);
gateOrLed.off();
// Reset allocators
mono[i].clear();
poly.clear();
pitchBend = 0;
outputFlag = true;
void output() {
// Update CVs (DACs)
unsigned int dacValues[4];
if (i < N) {
int pitchBendValue = pitchBend;
if (mode == MODE_POLY_MONO || mode == MODE_MONO_POLY) { // Pitch-bend is for monophonic voice only
if (!isNoteForMonophony(voiceMidiNote[i])) pitchBendValue = 0;
dacValues[i] = getMidiNoteCV(voiceMidiNote[i], pitchBendValue);
} else {
dacValues[i] = 0;
dac.analogWrite(
calibration[0].map(dacValues[0]),
calibration[1].map(dacValues[1]),
calibration[2].map(dacValues[2]),
calibration[3].map(dacValues[3])
// Update gates
bool active = voiceActive[i] && voiceRetrigTime[i] == 0;
digitalWrite(GATES[i], active);
gateLed[i].set(active);
// Update OR gate
bool gateOrActive = false;
byte gateOrFirstVoice = mode == MODE_MONO_POLY ? 1 : 0;
byte gateOrLastVoice = mode == MODE_POLY_MONO ? N - 2 : N - 1;
for (byte i = gateOrFirstVoice; i <= gateOrLastVoice; i++) {
gateOrActive |= voiceActive[i];
digitalWrite(GATE_OR, gateOrActive);
gateOrLed.set(gateOrActive);
void setModeLed() {
switch (mode) {
case MODE_POLY: setModeLedColor(MODE_POLY_RGB); break;
case MODE_POLY_FIRST: setModeLedColor(MODE_POLY_FIRST_RGB); break;
case MODE_POLY_MONO: setModeLedColor(MODE_POLY_MONO_RGB); break;
case MODE_MONO_POLY: setModeLedColor(MODE_MONO_POLY_RGB); break;
case MODE_MONO: setModeLedColor(MODE_MONO_RGB); break;
void setModeLedColor(unsigned long color) {
SoftPWMSet(MODE_LEDS[0], (color >> 16) & 0xFF);
SoftPWMSet(MODE_LEDS[1], (color >> 8) & 0xFF);
SoftPWMSet(MODE_LEDS[2], color & 0xFF);
} else {
digitalWrite(MODE_LEDS[0], (color >> 16) & 0xFF ? HIGH : LOW);
digitalWrite(MODE_LEDS[1], (color >> 8) & 0xFF ? HIGH : LOW);
digitalWrite(MODE_LEDS[2], color & 0xFF ? HIGH : LOW);
void handleNoteOn(byte channel, byte note, byte velocity) {
noteOnLed.flash();
if (isNoteForMonophony(note)) {
if (mode == MODE_MONO && (channel == 0 || channel > N)) return;
mono[getMonophonyStackIndex(channel)].noteOn(note);
byte i = getMonophonyVoiceIndex(channel);
voiceMidiNote[i] = note;
voiceActive[i] = true;
outputFlag = true;
} else {
int voice = poly.noteOn(note);
if (voice > -1) {
byte i = getPolyphonyVoiceIndex(voice);
if (voiceActive[i] && voiceMidiNote[i] != note) {
voiceRetrigTime[i] = millis(); // If that voice was already playing a different note, start a retrig interval
voiceLocked[i] = false; // Unlock the voice in case it was locked
outputFlag = true;
void handleNoteOff(byte channel, byte note, byte velocity) {
int newNote = mono[getMonophonyStackIndex(channel)].noteOff(note);
if (newNote > -1) {
voiceMidiNote[i] = newNote;
} else {
outputFlag = true;
} else {
int voice = poly.noteOff(note);
if (voice > -1) {
if (!voiceLocked[i]) { // De-activate voice if not locked
outputFlag = true;
void handlePitchBend(byte channel, int bend) {
pitchBend = bend;
outputFlag = true;
void handleCalibrationOffset(byte channel, byte note, byte velocity) {
if (calibrating) {
noteOnLed.flash();
gateOrLed.flash();
int offset = note >= (4 + 1) * 12 ? 1 : -1; // Split the keyboard in half on middle C
int v = calibration[calibratingVoice].get(calibratingInterval); // Current point value
calibration[calibratingVoice].set(calibratingInterval, max(0, v + offset)); // Move current point
bool isNoteForMonophony(byte note) {
bool higherKey = note >= (SPLIT_MIDI_OCTAVE + 1) * 12; // Check keyboard split
return ( // Return TRUE if the pressed note should be used for monophony
(mode == MODE_MONO) ||
(mode == MODE_POLY_MONO && higherKey) ||
(mode == MODE_MONO_POLY && !higherKey)
byte getMonophonyStackIndex(byte channel) {
return mode == MODE_MONO ? ((channel - 1) % N) : 0;
byte getMonophonyVoiceIndex(byte channel) {
if (mode == MODE_MONO) return (channel - 1) % N;
return mode == MODE_MONO_POLY ? 0 : N - 1;
byte getPolyphonyVoiceIndex(byte i) {
return mode == MODE_MONO_POLY ? i + 1 : i;
unsigned int getMidiNoteCV(byte note, int pitchBendValue) {
int lowestMidiNote = (LOWEST_MIDI_OCTAVE + 1) * 12;
float noteForCV = (float)note - lowestMidiNote;
if (pitchBendValue != 0) noteForCV += ((float)pitchBendValue / MIDI_PITCHBEND_MAX) * PITCH_BEND_SEMITONES;
return min(4000, max(0, round(noteForCV * MIDI_NOTE_TO_CV_FACTOR)));
String getMidiNoteName(byte note) {
String s = String(NOTE_NAMES[note % 12]);
s.concat((note / 12) - 1); // Octave
return s;
void debug(String line) {
if (DEBUG) {
if (DEBUG_WITH_TTYMIDI) {
Serial.write(0xFF);
Serial.write(0x00);
Serial.write(0x00);
Serial.write((byte)line.length());
Serial.print(line);
Serial.flush();
} else {
Serial.println(line);
void debugMidiNote(String line, byte note) {
if (DEBUG) {
String m = String(line);
m.concat(" ");
m.concat(note);
m.concat(" (");
m.concat(getMidiNoteName(note));
m.concat(")");
debug(m);
void debugVoices() {
if (DEBUG) {
String m = String("Voices: ");
m.concat(voiceActive[i] ? (voiceLocked[i] ? "{" : "[") : ".");
m.concat(getMidiNoteName(voiceMidiNote[i]));
m.concat(voiceActive[i] ? (voiceLocked[i] ? "}" : "]") : ".");
debug(m);
void bootAnimation() {
// Turn on all LEDs
gateLed[i].on();
delay(100);
gateOrLed.on();
delay(200);
// Turn them off
gateLed[i].off();
delay(100);
gateOrLed.off();
delay(100);
gateOrLed.loop();
delay(200);
Last edited by adafruit_support_carter on Fri Sep 30, 2022 9:21 am, edited 1 time in total.
Reason: added [code] tags
Where did the MCP4728 library being used in that code originate?
- Mindburner
hi i'm not sure
it may be the AVRfreaks one
https://www.avrfreaks.net/sites/default ... cp4728.cpp
and it needs changed for the A4
maybe that's the problem
- Mindburner
Think I have fixed it!
I edited the MCP4728.cpp file and changed
to
resaved, complied and sent to arduino
const uint8_t I2C_ADDR {0x60};
const uint8_t I2C_ADDR {0x64};
Cool. Yah, that seems right. That library has things more hardwired, like the I2C address. So would require changing the library code like you did.
For the Adafruit library:
https://learn.adafruit.com/adafruit-mcp ... ac/arduino
a non-default I2C address can be specified in the call to begin():
https://adafruit.github.io/Adafruit_MCP ... 146c4dc8ed
So would not require any code changes other than your user sketch code.
