Hi there,
I have an existing Dell 130w Power Supply and it has a cable fitted with a male 4.5mm Barrel Connector that plugs into the side of the Dell laptop with a female 4.5mm socket receptor.
I would like to use this existing power supply to power another Dell laptop that has a female USB Type C socket receptor on the side of the laptop.
I am seeking an adapter that would have the following characteristics.
1) Female 4.5mm barrel socket on one side
2) Male USB Type C socket on the other side
3) The adaptor would be rated for 130watts.
Can you please help!
Many thanks
Female 4.5mm Barrel Connector to Male USB Type C - Adaptor
- MarkDent
- Franklin97355
Re: Female 4.5mm Barrel Connector to Male USB Type C - Adaptor
Are the voltages the same and does the other dell restrict the USB C in any way? Since the power supply with the barrel jack does not know how to negotiate in USB C you might ruin the battery or laptop.
