I've started a little project to try and make a diybms using some Raspberry pi pico w's
and some of your LC709203F Fuel gauges.The idea was to have the LC709203F's connected
to the pico's read the battery cells and then send the reading's over MQTT to the Broker.
I've managed to get this to work fine when the pico is powered through the USB port
but when powered from the battery through VSYS on the Pico the program seems to only run so far.
I.E the wifi connects then the Mqtt seems to connect but no messages are sent.
I'm now wondering if the LC709203F is operating correctly when powered by the battery it is monitoring.
do you think it should work or am I barking up the wrong tree.
Thanks tonyek
# Complete project details at https://RandomNerdTutorials.com/micropython-mqtt-publish-bme280-esp32-esp8266/
import time
import ubinascii
import machine
import micropython
import network
import secrets
from LC709203F_CR import LC709203F
from simple import MQTTClient
from machine import Pin, I2C
import gc
gc.collect()
ssid = secrets.SSID
password = secrets.PW
mqtt_server = secrets.SERVER
client_id = ubinascii.hexlify(machine.unique_id())
topic_pub_volt = b'Fuel_Gauge/Cell_0/Voltage'
topic_pub_perc = b'Fuel_Gauge/Cell_0/Percentage'
topic_pub_temp = b'Fuel_Gauge/Cell_0/Temperature'
topic_pub_test = b'Fuel_Gauge/Cell_0/Test'
last_message = 0
message_interval = 20
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect(ssid, password)
while station.isconnected() == False:
pass
print('Connection successful')
led = machine.Pin('LED', machine.Pin.OUT)
for i in range(10):
led.on()
time.sleep(.5)
led.off()
time.sleep(.5)
i2c = I2C(1,scl=Pin(3), sda=Pin(2))
sensor = LC709203F(i2c)
sensor.thermistor_bconstant = 3950
sensor.thermistor_enable = True
def connect_mqtt():
global client_id, mqtt_server
client = MQTTClient(client_id, mqtt_server)
#client = MQTTClient(client_id, mqtt_server, user=your_username, password=your_password)
client.connect()
print('Connected to %s MQTT broker' % (mqtt_server))
return client
def restart_and_reconnect():
print('Failed to connect to MQTT broker. Reconnecting...')
time.sleep(10)
machine.reset()
for i in range(10):
led.on()
time.sleep(.5)
led.off()
time.sleep(.5)
def read_sensor():
try:
volt = str(round(sensor.cell_voltage, 2))
perc = str(round(sensor.cell_percent, 2))
temp = str(round(sensor.cell_temperature, 2))
return volt, perc, temp
#else:
# return('Invalid sensor readings.')
except OSError as e:
return('Failed to read sensor.')
try:
client = connect_mqtt()
while True:
try:
if (time.time() - last_message) > message_interval:
volt, perc, temp = read_sensor()
print(volt)
print(perc)
print(temp)
client.publish(topic_pub_volt, volt)
client.publish(topic_pub_perc, perc)
client.publish(topic_pub_temp, temp)
last_message = time.time()
