ESP32 Project: Button, switch, and output screen ?
For Adafruit customers who seek help with microcontrollers
cv127001
Post by cv127001 »
I'm a beginner with electronics and want to learn by doing a little project and would appreciate your help with parts selection for the project. I already have an Huzzah32 ESP32 Feather from Adafruit. I would like to connect to it an on/off switch, 3 sensor buttons (something easy to push with a finger), and an output screen where I can send some scores to, something easy to output text from the ESP32. By the way, I know my way around with programming.
Appreciate, in advance, any guidance you can give me.
Thank you,
Carlos
mikeysklar
Re: ESP32 Project: Button, switch, and output screen ?
Post by mikeysklar »
Carlos,
You can use a slide switch between the ENable and GND pin to control power on any Feather.
https://io.adafruit.com/blog/tip/2016/1 ... RPEALw_wcB
The Huzzah32 ESP32 Feather Learn Guide has some examples using buttons with WipperSnapper which is a good way to get started with input buttons and getting your device on-line quickly.
https://learn.adafruit.com/adafruit-huz ... pper-setup
There are so many display options that you will need to be specific about the desired size, but I'd start with buttons and power first.
cv127001
Post by cv127001 »
Mikey,
THANK YOU so much for helping me get started with the switch and buttons. I like that WipperSnapper - the name too :) .
I've been thinking about the screen, there are two options, but don't know how difficult each option might be. I prefer option 1, but 2 and 3 might be really nice too if not too difficult:
option 1: HDMI output
option 2: small LCD screen (something that fits in the hand)
option 3: some projectors have wifi and/or bluetooth capability to receive video feeds to project.
Thank you for your help, Mikey.
Carlos
mikeysklar
Carlos,
Please take a look at the Adafruit 2.13 FeatherWing eInk displays. They are designed to easily attach to the Huzzah32 and there is a guide for getting it going.
products;
https://www.adafruit.com/product/4195
https://www.adafruit.com/product/4814
guide:
https://learn.adafruit.com/adafruit-2-1 ... atherwings
Connecting to HDMI or projectors wirelessly while technically possible is not realistic for this controller. It can be achieved (barely) with some boards, but a Raspberry Pi would make it easy if you want to drive a real monitor or projector.
cv127001
Post by cv127001 »
Mikey,
That tri-color e-ink looks beautiful. Thank you for the guide. I'm going with the tri-color one :).
You have been very helpful. I really appreciate your help. Thank you Mikey.
Carlos
mikeysklar
Thank you and good luck on your project. Let us know how it goes.
cv127001
Post by cv127001 »
Will do, Mikey. :)
Carlos
Return to “Microcontrollers”
