I am stuck on how to get the ADABox020 LED glasses PCB to show up on my computer. I made sure I have a USB to USB-C data cable. I have power on. Cable is plugged into a USB data port. I have hit the reset button on the board. In File Explorer window I only see "C" and no other device or drive.
What other tricks do I need to do to get it to be visible? Or what the heck am I doing wrong???
Connecting LED glasses driver board to computer - not working
- Bobbier
Re: Connecting LED glasses driver board to computer - not working
File Explorer sometimes does not update when a new drive is discovered. Try pressing F5 to refresh. If that still doesn't show the new drive, try double clicking on "This PC".
- Bobbier
Thank you for those tips. I tried "F5" and I tried double clicking "My PC" - no change. I attached an image to show what I see.
Disconnect the USB cable and Open Device Manager.
When you plug it back in, does Device Manager refresh its display?
- Bobbier
Yes. The device manager refreshes and the is an audible be-boop when connecting and disconnecting.
That is a good sign. It is being recognized by the system. Can you determine which category in Device Manager it shows up as?
- Bobbier
I finally found it, sort of, in "Control Panel>Hardware and Sound> Devices and Printers>Unspecified" - where do I go from here?
Looks like it is correctly identifying as a LED Glasses device. Have you tried uploading the test sketch from the guide?
https://learn.adafruit.com/adafruit-eye ... ch-2860620
- Bobbier
I downloaded all the Arduino items and was able to copy the blinky light sketch and it appears to work. I was headed down the Circuit Python path. Given this was hard for me right now - should I follow along on Arduino or head over to Python?
And thank you for your help. I was getting frustrated.
The troubleshooting page covers some potential issues with recognizing the drive. Older versions of Windows and anti-virus software have been known to cause problems:
https://learn.adafruit.com/adafruit-eye ... ly-3004181
If that doesn't help, I can call in one of our CircuitPython experts to have a look.
