Rainmaker with QtPy ESP32-S2
ac400606
Post by ac400606 »
Hello everyone,
I have a QtPy ESP32-S2 and SHTC3 connected using STEMMA QT connector.
Based on Espressif's rainmaker documentation supports ESP32-S2 board.
While trying to upload using Arduino, I get this error
esptool.py v4.2.1
Serial port /dev/cu.usbmodem01
Connecting...
Chip is ESP32-S2FNR2
Features: WiFi, Embedded Flash 4MB, Embedded PSRAM 2MB, ADC and temperature sensor calibration in BLK2 of efuse V1
Crystal is 40MHz
MAC: 58:cf:79:a5:ea:48
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x001cafff...
Unexpected chip id in image. Expected 2 but value was 0. Is this image for a different chip model?
Compressed 18912 bytes to 13025...
Wrote 18912 bytes (13025 compressed) at 0x00001000 in 0.4 seconds (effective 417.3 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.1 seconds (effective 382.4 kbit/s)...
Compressed 8192 bytes to 47...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 501.5 kbit/s)...
Compressed 1811664 bytes to 1188323...
Wrote 1811664 bytes (1188323 compressed) at 0x00010000 in 22.8 seconds (effective 636.5 kbit/s)...
Leaving...
WARNING: ESP32-S2FNR2 chip was placed into download mode using GPIO0.
esptool.py can not exit the download mode over USB. To run the app, reset the chip manually.
To suppress this note, set --after option to 'no_reset'.
Has anyone had success with using rainmaker with QtPy ESP32-S2?
Any recommendations to troubleshooting are also welcome!
Regards
mikeysklar
Re: Rainmaker with QtPy ESP32-S2
Post by mikeysklar »
In the Arduino IDE what is the board being programmed being identified as? It should look like this:
Can you provide a screenshot of what your Tools --> Board selection looks like?
ac400606
Post by ac400606 »
Thanks for your reply. Selecting Adafruit Qt Py ESP32-S2 it doesn't show the partition table for Rainmaker.
so I have selected the board as ESP32S2 Dev Module after selecting this rainmaker partition scheme is available.
