macropad rp2040 can't find I2c adress of a neokey 1x4
vuduc09
Post by vuduc09 »
I buy 2 of them and plan to asem them. I am noob and i use a sample code of macrodpad rp2040. when I connect, macropad can't find I2c address of neokey 1x4 and neokey is inactive. What should I do now?
mikeysklar
Re: macropad rp2040 can't find I2c adress of a neokey 1x4
Post by mikeysklar »
Can you post a photo of how you have connected the MacroPad to the NeoKey? I want to confirm the stemma cable color orientation.
What code did you run to scan for the i2c address of the NeoKey on the MacroPad?
vuduc09
Post by vuduc09 »
mikeysklar wrote: Sun Oct 02, 2022 5:47 pm Can you post a photo of how you have connected the MacroPad to the NeoKey? I want to confirm the stemma cable color orientation.
https://drive.google.com/file/d/1yxOlJo ... sp=sharing
   // Scanning takes a while so we don't do it all the time
  if ((j & 0x3F) == 0) {
    Serial.println("Scanning I2C: ");
    Serial.print("Found I2C address 0x");
    for (uint8_t address = 0; address <= 0x7F; address++) {
      Wire.beginTransmission(address);
      i2c_found[address] = (Wire.endTransmission () == 0);
      if (i2c_found[address]) {
        Serial.print("0x");
        Serial.print(address, HEX);
        Serial.print(", ");
    Serial.println();
vuduc09
Post by vuduc09 »
I found that my stemma qt in my neokey is not working. When i change to use header pin it's work.
it's annoying
mikeysklar
Good to know the breakout pin header works.
That means the issue is likely one of the following:
1) The Stemma QT cable is reversed
2) The Stemma QT cable is not working
3) The Stemma QT connector (on either side) is damaged.
Can you use a multimeter to help narrow down which scenario is happening.
Was the Stemma cable purchased from Adafruit?
