Hi all, I'm following this tutorial (https://learn.adafruit.com/adafruit-fea ... rduino-ide) and having immense difficulty pairing the HUZZAH board with the Arduino IDE. I can't upload and run the blink example code.
I receive the following error "esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header"
I have tried the following to no avail:
- Adjusted the baud rate
- Purchased a new cable that connects from the HUZZAH board to laptop
- I have switched the board type to "Generic ESP8266 Module". Set the Reset Method to "nodemcu”
Additional Notes
- I have the proper drives installed (see image)
- Just for clarity, I don't have the breakout board. See --> https://learn.adafruit.com/adafruit-huz ... t/overview
- The Adafruit page says the HUZZAH board has "bootlegging capabilities" so I don't need to pull any pins low or high or press some buttons in a specific pattern. It's just upload and bob's your uncle
I have been troubleshooting this for days. Your suggestions will be immensely appreciated.
Difficulting running blink code on HUZZAH Board
- Catalyst__
- adafruit_support_carter
Re: Difficulting running blink code on HUZZAH Board
Just to check - were you originally selecting "Adafruit Feather HUZZAH ESP8266"?- I have switched the board type to "Generic ESP8266 Module". Set the Reset Method to "nodemcu”
- Catalyst__
Yes I was. I heard that selecting the Adafruit Feather HUZZAH ESP8266 option creates problems because it has bugs
Where did that information come from? It should work OK per the guide:
https://learn.adafruit.com/adafruit-fea ... rt-2720750
You're seeing the COM port show up in Device Manager as expected. So it seems like the CP2104 drivers are installed and working OK. That also indicates the USB cable is generally OK (bad USB cables are a huge source of issues).
Make sure nothing else is opening the COM port when the board is connected. Like some other 3rd party software.
- Catalyst__
adafruit_support_carter wrote: ↑Fri Oct 07, 2022 11:07 am Where did that information come from? It should work OK per the guide:
How do I make sure nothing else is opening the COM port when the board is connected?
Also, how do I reflash the bootloader? My professor said this will help
Try right clicking the COM port entry in Device Manager, select Properties, and then Details tab.How do I make sure nothing else is opening the COM port when the board is connected?
Another idea would be to try a different computer and see if the behavior repeats there.
You can't. The bootloader on the ESP8266 is a ROM bootloader. It can not be overwritten.Also, how do I reflash the bootloader? My professor said this will help
