Adafruit_NeoPixel.h: No such file or directory
mushZeng
Post by mushZeng »
I have installed the library ten times but still got this message:
Using board 'mzero_bl' from platform in folder: C:\Users\Mush Zeng\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Using core 'arduino' from platform in folder: C:\Users\Mush Zeng\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Detecting libraries used...
"C:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAM_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino M0\"" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\arduino_mzero" "C:\\Users\\Mush Zeng\\AppData\\Local\\Temp\\arduino-sketch-1F90C45F3FC48BC6197739E0057CF7FF\\sketch\\simple.ino.cpp" -o nul
Alternatives for Adafruit_NeoPixel.h: [[email protected]]
ResolveLibrary(Adafruit_NeoPixel.h)
-> candidates: [[email protected]]
"C:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAM_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino M0\"" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\Mush Zeng\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\arduino_mzero" "-IC:\\Users\\Mush Zeng\\BANNED\\文档\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\Mush Zeng\\AppData\\Local\\Temp\\arduino-sketch-1F90C45F3FC48BC6197739E0057CF7FF\\sketch\\simple.ino.cpp" -o nul
C:\Users\Mush Zeng\AppData\Local\Temp\.arduinoIDE-unsaved202293-27272-1r7lvz2.kjrq\simple\simple.ino:5:10: fatal error: Adafruit_NeoPixel.h: No such file or directory
compilation terminated.
Using library Adafruit_NeoPixel at version 1.10.6 in folder: C:\Users\Mush Zeng\BANNED\文档\Arduino\libraries\Adafruit_NeoPixel
exit status 1
Compilation error: Adafruit_NeoPixel.h: No such file or directory
Just don't know where is the problem. Could any one help me out? Thank you very much!
dastels
Re: Adafruit_NeoPixel.h: No such file or directory
Post by dastels »
What are the contents of C:\\Users\\Mush Zeng\\banned\\文档\\Arduino\\libraries\\Adafruit_NeoPixel?
mushZeng
Post by mushZeng »
i change another computer now it works fine. thank you !
dastels wrote: Tue Oct 04, 2022 8:02 am What are the contents of C:\\Users\\Mush Zeng\\banned\\文档\\Arduino\\libraries\\Adafruit_NeoPixel?
dastels
Post by dastels »
So it's something related to the installation of Arduino or it's libraries.
