Magtag Simple Project Selector
egomez4
Post by egomez4 »
I'm a bit stuck with my Magtag project. I wanted to make a simple project selector based on the Adafruit selector (https://learn.adafruit.com/adafruit-mag ... t-selector).
I just want a home screen to come up (cody.py) and then if I hit the first button it goes to the Weather.py project and if I hit the second button it goes to my Display.py project.
I am getting an error that says:
File "code.py", line 40, in <module>
File "weather.py", line 50, in <module>
File "adafruit_magtag/magtag.py", line 86, in __init__
File "adafruit_magtag/peripherals.py", line 53, in __init__
File "neopixel.py", line 141, in __init__
ValueError: NEOPIXEL in use
I did try to use magtag.deinit() but of course that's not working.
Here's the code.py. The two other codes (weather, display) are working:
import time
import alarm
import displayio
import board
from adafruit_magtag.magtag import MagTag
from digitalio import DigitalInOut, Direction, Pull
BACKGROUND_BMP = "/bmps/Select.bmp"
magtag = MagTag()
magtag.graphics.set_background(BACKGROUND_BMP)
magtag.set_text('')
projects = [
    "weather",
    "display",
while True:
    for i, b in enumerate(magtag.peripherals.buttons):
        if not b.value:
            if(i==0):                           ##If First button D15 is pressed
                selector = projects[0]
                print("Starting project ", selector)
                __import__(selector)
            if(i==1):                           ##If First button D15 is pressed
                selector = projects[1]
        else:
            None
        time.sleep(0.01)
I really appreciate the help!
adafruit_support_carter
Re: Magtag Simple Project Selector
There's no line 40 in the attached code.py.
But in general, it seems like what's happening is that Weather.py and Display.py are trying to also create a MagTag instance. Since there's already one created in code.py, this is a second instance and it runs into a conflict when it tries to initialize resources already in use - like the NEOPIXEL pin.
egomez4
Post by egomez4 »
Line 40 would have been __import__(selector).
That's what I'm trying to do, I'm trying to call another instance e.g. __import__(weather.py). This is how I thought the Magtag project selector calls other programs. Is there a way then to call weather.py and close code.py?
I want code.py to effectively be a start menu where I can open up other programs when I press the different buttons. I would then get back to the code.py program by hitting restart, and then I could select another program.
How would this be done? I tried to mimic the Magtag Project Selector Tutorial to no avail.
Note how the selector code in the guide does not create an instance of the magtag helper, i.e. this line in your code.py:
magtag = MagTag()
Instead, it's reading the buttons by manually creating digital in pins, like this:
btnA = DigitalInOut(board.D15)
btnA.direction = Direction.INPUT
btnA.pull = Pull.UP
You would need to do something similar in your code.
