Adafruit PCA9685 16-Channel Servo Driver, Pico, Continuous Rotation Servo
phesterman
Post by phesterman »
I've been experimenting with the Adafruit PCA9685 16-Channel Servo Driver and a Raspberry Pi Pico running CircuitPython to control a continuous rotation servo. And, using either the ServoKit or the PCA9685 sample code as a starting point, I've been generally successful. However, the servo literally runs continuously! Setting throttle=0 only seems to reduce the speed to about half; the servo doesn't stop. If I connect the servo directly to the Pico and use pwmio.PWMOut, throttle=0 stops the servo as expected, so the problem occurs when I use the PCA9685. Is there something I'm missing? (BTW, regular servos are working great with the PCA9685.)
dastels
Re: Adafruit PCA9685 16-Channel Servo Driver, Pico, Continuous Rotation Servo
Post by dastels »
The PCA9685 might be using slightly different pulse widths for "0". Do your Servos have a zeroing trim pot? You can try fiddling with that when throttle is set to 0 to get it to stop.
phesterman
Thanks for the reply. Yes, I tried using the trim pot, but it didn't make a noticeable difference. It's not like the servo is drifting slightly off from zero, it's more like the throttle is .25—.50.
dastels
Post by dastels »
Strange. Is this on mulriple servos or just a single one?
You could check for a way to set the min/max pulse width.
Hmm.. is any throttle setting that does stop the servo?
phesterman
Thanks again for the reply. I've not tried multiple continuous rotation servos, but I have combined continuous with several standard servos. I will experiment with what you've suggested...I haven't tried other throttle settings in any systematic way.
phesterman
OK. After taking a little time off from this, I started fresh and made more patient and careful adjustments of the trim pots. I've got several of them starting and stopping as expected now!
