code.py output:
File "code.py", line 6, in <module>
File "adafruit_debouncer.py", line 32, in <module>
ImportError: no module named 'adafruit_ticks'
This is what the Feather MO Express Lib looks like Every time I try to run the code - I keep getting a memory error like this
code.py output:
File "code.py", line 10, in <module>
File "adafruit_displayio_ssd1306.py", line 60, in <module>
MemoryError: memory allocation failed, allocating 64 bytes
code.py output:
File "code.py", line 9, in <module>
MemoryError: memory allocation failed, allocating 1450 bytes
# SPDX-FileCopyrightText: 2020 Collin Cunningham for Adafruit Industries
import board
from adafruit_debouncer import Debouncer
import digitalio
import displayio
from adafruit_display_text import label
import adafruit_displayio_ssd1306
from adafruit_bitmap_font import bitmap_font
displayio.release_displays()
# Set up button pins
pin_a = digitalio.DigitalInOut(board.D9)
pin_a.direction = digitalio.Direction.INPUT
pin_a.pull = digitalio.Pull.UP
pin_b = digitalio.DigitalInOut(board.D6)
pin_b.direction = digitalio.Direction.INPUT
pin_b.pull = digitalio.Pull.UP
pin_c = digitalio.DigitalInOut(board.D5)
pin_c.direction = digitalio.Direction.INPUT
pin_c.pull = digitalio.Pull.UP
button_a = Debouncer(pin_a) #9
button_b = Debouncer(pin_b) #6
button_c = Debouncer(pin_c) #5
# Load font
font = bitmap_font.load_font('/mround-31.bdf')
# Set up display & add group
i2c = board.I2C()
display_bus = displayio.I2CDisplay(i2c, device_address=0x3C)
display = adafruit_displayio_ssd1306.SSD1306(display_bus, width=128, height=32)
group = displayio.Group()
display.show(group)
# Add content to group
default_text = "I VOTE !"
text_area = label.Label(font, text=default_text, color=0xFFFFFF, x=0, y=17)
group.append(text_area)
while True:
# Debounce buttons
button_a.update()
button_b.update()
button_c.update()
# Check for button presses & set text
if button_a.fell:
text_area.text = default_text
text_area.x = 0
elif button_b.fell:
text_area.text = "I VOTED!"
text_area.x = 0
elif button_c.fell:
text_area.text = "DID U?"
text_area.x = 18
display.show(group)
