I run an application on a sw-code communicating with an IMU using I2C-protocol and it works fine on Arduino Uno, Adafruit M0 and Adafruit ESP8266 but when I run my application on the ESP 32 Feather, it won´t work.
I can isolate the problem to the initialization of the sensor, that is when I want to write the sensors registers setiing sensitivity etc. Nothing works.
At the same time I don´t have a problem to read regsiters, i.e. the "WHO AM I"-register.
Anyone that can offer some ideas on what to do?
Thanks in advance.
Leif
part of the code:
Wire.begin();
Wire.beginTransmission(GYRO_addr);
Wire.write(SENSOR_CONFIG0_addr);
Wire.write (sensorconfig); // ACC xyz and GYRO xyz enabled.
Wire.endTransmission(false);
ESP32 Feather, issues with I2C
- adafruit_support_carter
Re: ESP32 Feather, issues with I2C
Which specific ESP32 based Feather are you using? There are a few. Can you link to the product page.
- LeifLundberg
I'm using Adafruit Feather HUZZAH32-ESP32.adafruit_support_carter wrote: ↑Wed Oct 05, 2022 11:15 am Which specific ESP32 based Feather are you using? There are a few. Can you link to the product page.
OK, so not one of the version with low power features that can depower the whole I2C bus. So something else.
Do you know if the IMU does any clock stretching? Or has requirements for repeated starts?
- LeifLundberg
There is nothing in the Invensense's datasheet about that and please note that the test code works 100% with the basic Arduino UNO.
It could be some ESP32 specific quirk.
It sounds like you're writing your own driver? Or are you using an existing driver?
- LeifLundberg
This is my testcode working on M0, ESP8266 and UNO but not on ESP32:
// Sketch ICM-40627 test
#include "Wire.h"
uint16_t WHOAMI;
byte PWR;
byte sensorconfig=0b00000000; // 0
byte driveconfig =0b00001001; // 9
byte pwrmgmnt0 = 0b00001111; // 15
byte accelconfig01 = 0b00001111; // 15
byte gyroconfig0 = 0b000100110; // 38
byte accelconfig02 = 0b00000110; // 6
// ICM-40627-adresses
const int GYRO_addr = 0x68;
const int SENSOR_CONFIG0_addr = 0x03;
const int DEVICE_CONFIG_addr = 0x11;
const int DRIVE_CONFIG_addr = 0x13;
const int INT_CONFIG_addr = 0x14;
const int FIFO_CONFIG_addr = 0x16;
const uint8_t PWR_MGMNT0_addr = 0x4E;
const uint8_t GYRO_CONFIG0_addr = 0x4F;
const uint8_t ACCEL_CONFIG0_addr = 0x50;
const uint8_t GYRO_CONFIG1_addr = 0x51;
const uint8_t GYRO_ACCEL_CONFIG0_addr = 0x52;
const uint8_t ACCEL_CONFIG1_addr = 0x53;
const uint8_t WHO_AM_I_addr = 0x75;
Serial.begin(115200);
Wire.begin();
Wire.write(WHO_AM_I_addr); // register low X-data
Wire.requestFrom(GYRO_addr, 1, true);
WHOAMI = Wire.read();
Serial.print("WHOAMI:");
Serial.println(WHOAMI);
delay(500);
delay(500);
Init_ICM40627();
delay(500);
void Init_ICM40627(){
Wire.begin();
PWR = Wire.read();
Serial.print("SENSOR CONFIG:");
Serial.println(PWR);
Wire.begin();
Wire.write(DRIVE_CONFIG_addr);
Wire.write (driveconfig); // bits 5:3=1, bits 2:0 = 1
PWR = Wire.read();
Serial.print("DRIVE CONFIG:");
Wire.begin();
Wire.write(PWR_MGMNT0_addr);
Wire.write (pwrmgmnt0); // both gyro and accelerometer in low noise mode. Temperature sensor enabled.
PWR = Wire.read();
Serial.print("PWR_MGMNT0:");
Wire.begin();
Wire.write(ACCEL_CONFIG0_addr);
Wire.write (accelconfig01); // bit 7-5: 00x which means +/- 16G, bit 3-0: 1111 which means 500 Hz ODR
PWR = Wire.read();
Serial.print("ACCEL CONFIG0:");
Wire.begin();
Wire.write(GYRO_CONFIG0_addr);
Wire.write (gyroconfig0); // bit 7-5: 0001 which means 1000 dps sensitivity, bit 4 reserved, bit 3-0: 0110 which means 1000 Hz ODR
PWR = Wire.read();
Serial.print("GYRO CONFIG0:");
Wire.begin();
Wire.write (accelconfig02); // bit 7-5: 000 which means +/- 16G sensitivity, bit 3-0: 0110 which means 1000 Hz ODR
PWR = Wire.read();
Serial.println(PWR);}
Last edited by adafruit_support_carter on Thu Oct 06, 2022 11:19 am, edited 1 time in total.
Wire.begin() should only be called once. Try removing the extra calls.
