BEST 102C Issue
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
amalone515
BEST 102C Issue
Post by amalone515 »
I'm having issues with the BEST adjustable soldering iron (Product ID 3685) not sufficiently heating up. I'm unable to create any joints or even tin the tip. At max temp when I hold the solder against the tip for a long time, the solder will, at best, bead up.
I've tried changing the tip, using a different outlet, and giving it ample time to heat up. If there's anything else I should be trying, please let me know.
Order Confirmation No: 2923575-2775707245 (19 Sep 2022)
Alex
adafruit_support_mike
Re: BEST 102C Issue
There isn't much DIY troubleshooting for that one.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement.
Return to “Tools Tools Tools”
