Problem with compiling Circuit Playground Bluefruit
Play with it! Please tell us which board you're using.
mrpibbtsa
Post by mrpibbtsa »
Hi there,
I have used Circuit Playground Express for some Python projects to some good success, and I am working on my first Arduino project on a Playground Bluefruit device.
I’m working through on of the example codes, controller, and am having issues.
I’m able to compile and run the included example demo for CPE on the Bluefruit, but when I try to compile any code that uses Adafruit_BLE.h, I get the following error:
 In file included from c:\Users\georg\Documents\Arduino\libraries\Adafruit_BluefruitLE_nRF51/Adafruit_BLE.h:42,
                 from C:\Users\georg\AppData\Local\Temp\.arduinoIDE-unsaved202299-32532-18dmo6n.h24a\controller\packetParser.cpp:8:
c:\Users\georg\Documents\Arduino\libraries\Adafruit_BluefruitLE_nRF51/utility/common_header.h:74:20: error: redefinition of 'bool is_within(uint32_t, uint32_t, uint32_t)'
   74 | static inline bool is_within(uint32_t lower, uint32_t value, uint32_t upper)
In file included from C:\Users\georg\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\cores\nRF5/rtos.h:45,
                 from C:\Users\georg\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\cores\nRF5/Arduino.h:48,
                 from C:\Users\georg\AppData\Local\Temp\.arduinoIDE-unsaved202299-32532-18dmo6n.h24a\controller\packetParser.cpp:2:
C:\Users\georg\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\cores\nRF5/common_func.h:317:20: note: 'bool is_within(uint32_t, uint32_t, uint32_t)' previously defined here
  317 | static inline bool is_within(uint32_t lower, uint32_t value, uint32_t upper)
In file included from c:\Users\georg\Documents\Arduino\libraries\Adafruit_BluefruitLE_nRF51/Adafruit_BLE.h:43,
c:\Users\georg\Documents\Arduino\libraries\Adafruit_BluefruitLE_nRF51/utility/errors.h:112:53: error: 'ERROR_NONE' conflicts with a previous declaration
  112 |     ERROR_NONE                                    = 0x0000,   ///< Successful command
In file included from C:\Users\georg\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\cores\nRF5/Arduino.h:26,
C:\Users\georg\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\cores\nRF5/wiring_constants.h:75:3: note: previous declaration '<unnamed enum> ERROR_NONE'
   75 |   ERROR_NONE = 0
c:\Users\georg\Documents\Arduino\libraries\Adafruit_BluefruitLE_nRF51/utility/errors.h:196:3: error: conflicting declaration 'typedef enum err_t err_t'
  196 | } err_t;
C:\Users\georg\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\cores\nRF5/wiring_constants.h:71:18: note: previous declaration as 'typedef uint32_t err_t'
   71 | typedef uint32_t err_t;
exit status 1
Compilation error: exit status 1
When I compile something that doesn’t have Adafruit_BLE.h, like the beacon example, it works fine.
I’m not very familiar with Arduino but I’ve been able to run several demos just fine on the CPE - struggling here with any of the BLE functions on the Bluefruit.
George
adafruit_support_carter
Re: Problem with compiling Circuit Playground Bluefruit
Are you selecting the example sketch from the Examples menu of the nRF52 BSP?
https://learn.adafruit.com/adafruit-cir ... o-examples
mrpibbtsa
Post by mrpibbtsa »
adafruit_support_carter wrote: Mon Oct 10, 2022 11:56 am Are you selecting the example sketch from the Examples menu of the nRF52 BSP?
Thank you! Examples from this folder are working for me.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
