Nice looking bot build you got there. I think we have discussed it before.
The Google Assistant guide will take some time to resolve (not fast).
There are other guides showing essentially the same process. You might want to review some of them to see if they figured out how to get through an updated Google oauth process.
https://pimylifeup.com/raspberry-pi-google-assistant/
https://www.instructables.com/Google-As ... erry-Pi-1/
https://www.hackster.io/Shailesh-Coder/ ... way-eee782
https://medium.com/@kevalpatel2106/turn ... 29ad220075
Google assistant with voice bonnet
- ps_nithin
- ps_nithin
Re: Google assistant with voice bonnet
I am getting authorization code by running local web server on the host machine. I modified the url to
On the local web server root i placed the file auth.php with following code.
Then it displays the authorization code.
But when i paste the authorization code on raspberry pi i am getting the following output I suppose it is because redirect_uri has changed. But i am not sure how to edit oauthlib python library files.
https://accounts.google.com/o/oauth2/v2/auth?scope=email%20profile&response_type=code&redirect_uri=http%3A//127.0.0.1%3A80/auth.php&client_id=<client_id>
<?php
$ga_auth_code=$_GET['code'];
echo $ga_auth_code;
- ps_nithin
Google assistant might take a while to work. I am using this speech recognition library for now. https://pypi.org/project/SpeechRecognition/. I am happy with the results. https://twitter.com/ps__nithin/status/1 ... DeuSg&s=19
- mikeysklar
Cool. Thank you for sharing this. I've not heard of this python based SpeechRecognition before, but it looks a lot more friendly to setup.
- MakerMelissa
Sorry for the delay. I was out sick with COVID. Anyways, there were a couple of issues I bumped into.
1. There was the first one you mentioned. I figured out that by leaving the Google project in test mode and not publishing, but adding yourself as a test user fixes it.
2. The other issues was that software package updates broke the code and that had to be sorted out. I just finished updating the guide and code and testing it out so you should be good to go.
Melissa
Melissa
- mikeysklar
Thank you @MakerMelissa.
- ps_nithin
Thank you @MakerMelissa. Google assistant is now working on my device.
