1-This is very encouraging. I also uploaded this code and got a similar result:
Adafruit SPIFlash Animated GIF Example
Flash chip JEDEC ID: 0xC84017
Mounted filesystem!
142692 2022-09-27 16:22 Arduino-Logo-320.gif
4096 2022-10-31 17:53 ._Arduino-Logo-320.gif
22 2020-01-01 00:00 code.py
0 2020-01-01 00:00 lib/
115 2020-01-01 00:00 boot_out.txt
Successfully opened GIF Arduino-Logo-320.gif; Canvas size = 320 x 170
frame count: 1
duration: 40 ms
max delay: 40 ms
min delay: 10000 ms
2- BUT, my screen is still black AND when I change the DISPLAY_HEIGHT in the code from 174 to 170 to fit the dimensions of my screen, I recieve this message:
Mounted filesystem!
4096 2022-10-31 17:50 ._Arduino-Logo-320.gif
frame count: 1
duration: 40 ms
max delay: 40 ms
min delay: 10000 ms
Error opening file ._Arduino-Logo-320.gif = 8
and I recive this error message while uploading:
Arduino: 1.8.19 (Mac OS X), Board: "Adafruit Feather RP2040, 8MB (no FS), 133 MHz, Small (-Os) (standard), Disabled, Disabled, Disabled, Disabled, None, Pico SDK, IPv4 Only"
Sketch uses 73804 bytes (0%) of program storage space. Maximum is 8384512 bytes.
Global variables use 33348 bytes (12%) of dynamic memory, leaving 228796 bytes for local variables. Maximum is 262144 bytes.
Resetting /dev/cu.usbmodem14201
Converting to uf2, output size: 179200, start address: 0x2000
Flashing /Volumes/RPI-RP2 1 (RPI-RP2)
Wrote 179200 bytes to /Volumes/RPI-RP2 1/NEW.UF2
processing.app.SerialException: Error opening serial port '/dev/cu.usbmodem14201'.
at processing.app.Serial.<init>(Serial.java:152)
at processing.app.Serial.<init>(Serial.java:82)
at processing.app.SerialMonitor$2.<init>(SerialMonitor.java:132)
at processing.app.SerialMonitor.open(SerialMonitor.java:132)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:132)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2126)
at processing.app.Editor.access$1300(Editor.java:116)
at processing.app.Editor$UploadHandler.run(Editor.java:2095)
at java.lang.Thread.run(Thread.java:748)
Caused by: jssc.SerialPortException: Port name - /dev/cu.usbmodem14201; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.<init>(Serial.java:141)
... 8 more
3- I tried to upload the code that is working and unplugg the whole thing from the computer and power it with a battery. I tried with and without switch. The screen is still black
RP2040 and TFT, Mini GIF player "Error opening file" (black screen)
- Laila_Mestari
- mikeysklar
Re: RP2040 and TFT, Mini GIF player "Error opening file" (black screen)
The code is uploading and running again.
I need you to go over the display connections. Shorten the wires, use hookup cable if you have it and confirm continuity to each pin with a multi-meter. Then take a photo of your setup so I can confirm the wiring.
- Laila_Mestari
Ok, I will do that.
Are you able to see the GIF playing on your circuit?
- Laila_Mestari
Ok, I will do that.
- mikeysklar
I don’t have this display, only the RP2040 to run the code on.
- Laila_Mestari
I have not shorten my wires because I checked my connections again and they are perfect so I know that the problem is not there. And I am using hook-up wires.
Here is what I see:
-The code is running when nothing is changed on it. It "successfully opens" the file but, there are still some strange thing going on:
A) the screen doesn't play anything
B) I think it is still wierd that the message says:
Successfully opened GIF Arduino-Logo-320-B.gif; Canvas size = 320 x 170
frame count: 1
duration: 40 ms
max delay: 40 ms
min delay: 10000 ms
duration: 40 ms
max delay: 40 ms
min delay: 10000 m
C)
Each time the switch is turned off and then on, the serial monitor adds these line to the message:
4096 2022-11-02 14:11 ._Arduino-Logo-320.gif
which is exactly the same problem i had at the very begining
What I see is that Engineers were able to solve my most recent problem, which arised after I reached out to you for my fisrt problem but now, we are back at the begining.
It seems to me that the RP2040 is creating an invisible file ("._Arduino-Logo-320.gif") each time that it is turned off and then it causes problem when the device is on even if there are no invisible files to start with on my RP2040.
I think the only way to verify if this project is working at this point is that you connect everything to a screen and see what happens.
Here is what I see:
frame count: 1
duration: 40 ms
max delay: 40 ms
min delay: 10000 ms
duration: 40 ms
max delay: 40 ms
min delay: 10000 m
C)
- mikeysklar
I have ordered the display needed to replicate the guide and will let you know if I have success with it or reproduce your findings.
- Laila_Mestari
Sounds great! Looking forward to hear back from you
- mikeysklar
Parts arrived and I wired up the RP2040 + 1.9" IPS TFT. I had no issue with the code building or uploading. My display stayed black.
I went back to the source and modified the pins since RP2040 boards tend to use a GPIO prefix when referencing the pin numbers on the PCB. I figured the pin numbers were off and adjusted it from the D-pin name to the GPIO internal numbering.
The wiring stays the same, but change these pins:
5 --> 7
6 --> 8
The code should now read:
You can see the confusion looking at the RP2040 pinout chart.
Now I have GIFs. Serial console needs to be opened.
5 --> 7
6 --> 8
#define TFT_CS 7
#define TFT_DC 8
#define TFT_RST 9
- Laila_Mestari
Thank you so much, that sounds great!
I am going to try to do the same as soon as I have access to my material and let you know how it goes.
- mikeysklar
Sounds good.
One further point of confusion is the default Arduino-320.gif installed by CircuitPython. Be sure and remove that. It is not part of the set of GIFs included with the adafruit_gifs/320 folder. Start with the badger one since I confirmed that it works.
The pins being numbered differently is just the difference between CircuitPython numbering on top and Arduino on the bottom side of the RP2040 Feather.
- Laila_Mestari
I was about to try it out today, but when I opened my RP2040, I could see that the files are locked, so I cannot load Nuke or CircuitPython on it... When I go on "Get Info", it looks like the computer doesn't allow me to uncheck the "locked" box... I updated my Mac some days ago, so that is probably why, but there must be a way to go around it. Please let me know if you can help with that
- Screenshot 2022-11-25 at 1.25.42 PM.png (131.51 KiB) Viewed 123 times
- Laila_Mestari
problem in last post was resolved
- mikeysklar
What was the solution to the locked file problem you briefly encountered? I had not seen that before.
- Laila_Mestari
I just had to open the locked files with TextEdit and unlock them from there. But still after this, the UF2 and Nuke files would not copy onto the RPI-RP2 Volume. I found out that this was the symptom of a more complex problem explained here:
https://www.raspberrypi.com/news/the-ventura-problem/
I looks like there are some recent dysfunctions between Mac updating systems (Ventura) and Raspberry Pie products...But I did copy the UF2 file successfully using the terminal of my computer, as suggested on this article. However, I still have some issues with loading the code on my RP2040.
When I use Arduino 1.8.19, the code is compiled without problem but it gives me this error message every time I upload it on the board:
No drive to deploy.
An error occurred while uploading the sketch
No drive to deploy.
