Two Ground Pins On Metro Mini
axetronic
Post by axetronic »
Wondering why there are two gnd pins on the Metro Mini, and which one to use?
Is it possible, as I have read, that you can plug a regulated +5V into the 5V pin in order to supply external power?
Sincere thanks,
Tony
Franklin97355
Re: Two Ground Pins On Metro Mini
Post by Franklin97355 »
The ground is a common port that is shared with all devices so it may need multiple connections. You can connect a regulated 5 volt power source and ground to the mini.
axetronic
Post by axetronic »
Thank you very much for the info.
Tony
Return to “Metro, Metro Express, and Grand Central Boards”
