rotaryio not included with Trinket M0?
mike3d0g
Post by mike3d0g »
How do I read a rotary encoder on with the Trinket M0? The docs make it look easy, but they use the rotaryio module as a built-in, and it's not loading for me.
Sample code:
import rotaryio
import board
encoder = rotaryio.IncrementalEncoder(board.D10, board.D9)
last_position = None
while True:
    position = encoder.position
    if last_position is None or position != last_position:
        print(position)
    last_position = position
The Adafruit tutorial page says "CircuitPython 4.x and later come with rotaryio built in". https://learn.adafruit.com/rotary-encoder/circuitpython
And the CircuitPython docs page says it's supported on the Trinket MO.
https://docs.circuitpython.org/en/lates ... index.html
dastels
Re: rotaryio not included with Trinket M0?
Post by dastels »
It should be included.
Adafruit Trinket M0
analogio, array, board, builtins, busio, collections, digitalio, math, microcontroller, neopixel_write, nvm, os, pwmio, rainbowio, random, rotaryio, rtc, storage, struct, supervisor, sys, time, touchio, usb_cdc, usb_hid, usb_midi
What exactly do you see in the REPL?
mike3d0g
Post by mike3d0g »
Ooops, I should have included that.
Adafruit CircuitPython 3.1.1 on 2018-11-02; Adafruit Trinket M0 with samd21e18
>>> import rotaryio
  File "<stdin>", line 1, in <module>
ImportError: no module named 'rotaryio'
I found this page of libraries, I think I need to install one. None are labeled for version 3, should I use the bundle named adafruit-circuitpython-bundle-py-20221014.zip?
https://github.com/adafruit/Adafruit_Ci ... e/releases
dastels
Post by dastels »
Oh.. that's an OLD version of CircuitPython... pre-rotario as I recall.
Get updated to CircuitPython 7.3.3.
mike3d0g
Post by mike3d0g »
Ha! It's a new Trinket and it didn't even occur to me. I've been missing some of the newer Python language features. Thanks for the help!
dastels
Post by dastels »
No worries. The Trinket M0 was added to the shop some time ago. It's always a good idea to update things when you get them. You should update the bootloader while you're at it.
