Hi everyone,
I am making the fairy wings project that is posted on adafruit's website. I am a complete beginner so all of this stuff is new to me. Anyhow, I cannot seem to calibrate the servos or even get them to move. I thought I programmed the feather express but when I plug it into my computer via usb, the light flashes green, purple then yellow and another yellow. I don't really know what I'm doing wrong.
I took screen shots which I attached to this post and I will also describe what I'm seeing.
CIRCUITPY
adafruit-circuitpython-fea..._express-en_US-7.3.3.uf2
boot_out.txt
code.py
code.py.sb-c1cde9e8-djhPI7
code.py.sb-c1cde9e8-RdQ02h
code.py.sb-c1cde9e8e-y2An6w
lib
_______
the lib folder has this stuff:
adafruit_bus_device
adafruit_motor
adafruit_pca9685.mpy
adafruit_register
adafruit_servokit.mpy
if I try to open these files my macbook asks me what program do you want to open the file in and I have no idea what program/application to use or if I should even be opening these files
________
the code.py file just has exactly what I cut and pasted from adafruit's website
______
Thanks in advance for your help :)
problem with feather m4 express for fairy wings
- fairywings82
- Screen Shot 2022-10-18 at 2.11.12 PM.png (210.13 KiB) Viewed 255 times
- Screen Shot 2022-10-18 at 2.11.02 PM.png (162.77 KiB) Viewed 255 times
- Screen Shot 2022-10-18 at 2.10.52 PM.png (224.64 KiB) Viewed 255 times
- dastels
Re: problem with feather m4 express for fairy wings
You should see what is being output in the REPL when you get those flashing colors (they indicate an error).
You can't do anything with MPY files. They are precompiled python code which are smaller to store, faster to load, and don't take memory to compile when they are loaded.
The first things to do is figure out that error.
- adafruit_support_carter
This behavior:
Also seeing that you have the CircuitPython firmware UF2 file (adafruit-circuitpython-feather_m4_express-en_US-7.3.3.uf2) sitting in the CIRCUITPY folder. That indicates the board was not put into bootloader mode first - which should show a folder named BOOT.
Let's get that sorted first. Go ahead and just delete the .uf2 file sitting in the CIRCUITPY folder. Then, go back to this part of the guide:
https://learn.adafruit.com/animatronic- ... m4-express
and make sure you are getting into bootloader mode, see the folder with BOOT in the name, and drag the .uf2 file to that.
sounds like an error code being displayed on the RGB LED.the light flashes green, purple then yellow and another yellow
- fairywings82
Thanks for helping me.
So I deleted the UF2 file. I don't see a boot folder. I only have boot_out.txt Do you know how I can get into boot mode?
- fairywings82
Should I erase everything from it and start over? If yes, can you please tell me how to do that step by step? Thanks
Double press the reset button.Do you know how I can get into boot mode?
- fairywings82
So I pressed reset twice and it's blinking green. When I click on it, it doesn't say featherboot, it just says circuitpy. Should I disconnect it and press reset again or should I delete everything off of it and then disconnect, reconnect and press reset again? Sorry for all of the questions but I'm not sure what I'm doing wrong.
- Screen Shot 2022-10-19 at 10.35.14 AM.png (148.53 KiB) Viewed 222 times
- dastels
As the guide says, try different timing with the double-presses. It should mount a drive named FEATHERBOOT.
- fairywings82
thanks Dave, two fast clicks worked. fingers crossed I can get this working
- fairywings82
I have the servos working and they are calibrated. I just have a quick question. When the motors are working, they pause when the wings are perpendicular to your shoulders. Is it possible to change part of the code so the pause happens when the wings are fully open or parallel to the shoulders? If this can be changed, can you please let me know exactly what I would have to change and where I could find it in the code. As always, thanks for the help. It is greatly appreciated.
- dastels
Just looking at the code, I'd say that the line near the end: could be moved to just after
time.sleep(random.randint(2, 10)) # wait 2 to 10 seconds
print("Close")
- fairywings82
I moved the code as suggested and I got the dreaded blinking red light. I think I'm going to just leave it alone. Thanks for all of the help.
- dastels
If there's a problem with the code error information will get output to the REPL whick will tell you what's happening.
