Hi, I'm jose,
I need help with customizing the ufo code that is provided. I would like my light ring to do the exact thing in the video Adafruit made on the project.
https://learn.adafruit.com/ufo-drone/code
this is the link to the project.
Need Help with UFO Code
- mikeysklar
Re: Need Help with UFO Code
Have you been able to assemble and run the example code? Using the theaterChase function set to green should get you the tractor beam effect shown in the video. This would be used in the main loop() in place of the other functions.
theaterChase(strip.Color(0, 255, 0), 50);
- Dcat
Yes, the strand test wheel code does work. I just wanted the tractor-beam effect. Thanks, I haven't had the time to learn the code.
- Dcat
Ok, I have no clue where this line of code goes. This is what I have now not really sure what to do.
// Some example procedures showing how to display to the pixels:
//colorWipe(strip.Color(255, 0, 0), 50); // Red
//colorWipe(strip.Color(0, 255, 0), 50); // Green
//colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
// Send a theater pixel chase in...
//theaterChase(strip.Color(127, 127, 127), 50); // White
//theaterChase(strip.Color(127, 0, 0), 50); // Red
theaterChase(strip.Color(0, 0, 127), 50); // Blue
//rainbow(20);
//rainbowCycle(20);
//theaterChaseRainbow(50);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i+q, 0); //turn every third pixel off
//rainbow(20);
//rainbowCycle(20);
strip.show();
delay(wait);
- Dcat
Also, the ring has four colors going around. red,green,blue,and white.
- Dcat
Also, I'm using the NeoPixel 1/4 60 Ring - 5050 RGBW LED w/ Integrated Drivers. Not sure if there are any differences between the code for the smaller rings.
