I am attempting to do this project
https://learn.adafruit.com/capacitive-t ... icorn-horn
but when the battery is plugged in the LEDs won't light up. The code seems to be working. When I tested the LEDs with a power supply they would not turn on. I did exactly as the instructions said. The single LED works fine and will turn on and off when D2 is touched. I believe the Neopixel LEDs are not working. Can I return for a replacement or refund?
Order number 2930174-7105352422
NeoPixel Ring - 12 x 5050 RGB LED with Integrated Drivers
ordered 09/29/2022
Neopixel 12 5050 not working
- Franklin97355
Re: Neopixel 12 5050 not working
Can we see a picture of your setup and the soldering?
- vrosario89
Franklin97355 wrote: ↑Wed Oct 19, 2022 6:17 pm Can we see a picture of your setup and the soldering?
I've disassembled it to check it with the power supply
