Hi All,
I've added the /etc/udev/rules.d entry to allow the dialout group access to the USBtiny device 1781:0c9f:
SUBSYSTEM=="usb", ATTR{product}=="USBtiny", ATTR{idProduct}=="0c9f", ATTRS{idVendor}=="1781", MODE="0660", GROUP="dialout"
I am indeed a member of the dialout group.
I can see the device in 'lsusb'
If I run 'dmesg -w' and plug the trinket in I can see it detecting but not getting a /dev/ttyX assignment:
[ 1071.236126] usb 1-3: USB disconnect, device number 12
[ 1073.960212] usb 1-3: new low-speed USB device number 13 using xhci_hcd
[ 1074.114970] usb 1-3: New USB device found, idVendor=1781, idProduct=0c9f, bcdDevice= 1.05
[ 1074.114973] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1074.114974] usb 1-3: Product: Trinket
[ 1074.114975] usb 1-3: Manufacturer: Adafruit
also note that if I run lsusb -t -v I get this for that device:
|__ Port 3: Dev 13, If 0, Class=, Driver=, 1.5M
ID 1781:0c9f Multiple Vendors USBtiny
Should I be concerned that the Driver entry is blank?
Hope to hear from you,
Randy in Seattle
Can't get a port in Arduino 2.0 IDE for Trinket in in Ubuntu22
- randyrue
- dastels
Re: Can't get a port in Arduino 2.0 IDE for Trinket in in Ubuntu22
This is one of the old trinkets? If so, problems are not surprising. There's a warning on the product page:
DaveDeprecation Warning: The Trinket bit-bang USB technique it uses doesn't work as well as it did in 2014, many modern computers won't work well. So while we still carry the Trinket so that people can maintain some older projects, we no longer recommend it. Please check out the Trinket M0. It has built-in USB, more capabilities, and is comparable in price!
