Need some help here just can't get SPIFFS to mount on this board.
Using Arduino 1.8.19 with esp core 2.0.5
I have selected a SPIFFS partition scheme tried several, I have run the SPIFFS test sketch and it will not mount. I have tried SPIFFS.format(); then run the test sketch again still nothing.
I have just got it working fine on a Unexpected maker ESP32-S3 feather and an Adafruit ESP32-S2 feather so what is the problem with this board? :(
Feather ESP32-S3 4Flash 2PSRAM. SPIFFS will not mount.
- mabateman
- mabateman
Re: Feather ESP32-S3 4Flash 2PSRAM. SPIFFS will not mount.
Adafruit Support, do you have anything on this?
If possible can you pick up this board out of your stock and try running the SPIFFS_Test example??
I really need to know if this is a faulty board or if something is not working with the config in Arduino IDE.
Thanks in advance!
Thanks in advance!
There's a known bug in the ESP32-S3 firmware that interferes with SPIFFS:
https://github.com/espressif/arduino-esp32/issues/6614
- mabateman
Hi Mike,
I have it working fine on 2 Unexpected Maker ESP32-S3 Feathers same Arduino Version, Same Core, same test sketch!
Reading through that bug from back in April it states at the end it was fixed in core 2.0.4 I am running 2.0.5
Given it is working on other S3 dev boards are we sure the Adafruit boards definition for this board has the correct parameters?
I'll check with the folks who manage the core.
- adafruit2
mab, please post a screenshot of the tools menu so we see the exact settings you've got going on!
- mabateman
Yes of course,
The only thing I am selecting different from default is selecting a partition scheme with SPIFFS included.
- adafruit2
ok we probably have some error in the parition table... will look to see whats different.
in the meantime, could you try selecting the Espressif S3 Generic Dev board (don't have IDE on this computer so can't give the exact name) and select 4 MB flash SPIFFS does it work then?
- mabateman
Flashing the SPIFFS_test as ESP32S3 Dev Module with the default SPIFSS partition option gives the following error in the serial output...
22:21:24.411 -> E (3059) SPIFFS: mount failed, -10025
- adafruit2
ok - this sorta makes me wonder if its an IDE issue with the 4MB mapping. its almost certainly not hardware because the SPI flash is what your code is running from.
last question, ifyou use the Umaker Feather and select the same 4MB flash SPIFFS 'generic ESP32S3 dev board' does it work then?
- mabateman
If I select board "ESP32S3 Dev Module" and flash the test sketch to the UM feather S3 the sketch won't even run so I don't think the UM is compatible with "ESP32S3 Dev Module" the UM is 16MB flash anyway so different profile.adafruit2 wrote: ↑Fri Nov 04, 2022 9:18 pm ok - this sorta makes me wonder if its an IDE issue with the 4MB mapping. its almost certainly not hardware because the SPI flash is what your code is running from.
SPIFFS works fine on the UM Feather S3 with its own board profile.
SPIFFS works fine on the Ada Feather S2 with its own board profile.
I can't see why it would be the IDE?
I see mention of another person unable to use SPIFFS on the Ada Feather S3. Has anyone else just picked up an Ada S3 board and tried it?
- adafruit2
the reason it could be the IDE is that the ESP32-S3 board definition from Espressif is for the 'module' not the 'feather' so its not the feather definition. and the flash memory is built into the chip itself so it cant be miswired. we'll have an engineer try this out some time this week.
- hathach
Hi, we are able to narrow this down to an obsolete present of partitions.csv (only leftover for this feather esp32s3). We will make an PR to fix this, meanwhile please manually remove this file arduino-esp32/variants/adafruit_feather_esp32s3/partitions.csv and reload your IDE. The new partition scheme will take affect.
link to variant in github repo
https://github.com/espressif/arduino-es ... er_esp32s3
PS: we made PR to espressif repo, hopefully It could make into the next release https://github.com/espressif/arduino-esp32/pull/7438
- mabateman
Yes that worked, thanks!
- spiff72
Is this definitely not common with the ESP32S2? I have been struggling with getting SPIFFS to work on my Feather S2 TFT:
viewtopic.php?p=950504#p950504
