I’ve had luck before with the trinket mo but not with this one. I’ve done everything I’ve done on another and keep getting the red light flashing twice error. I’ve updated the uf-2 to 7.3 and tried 8.0 and keep getting same error. Any suggestions?
Also I’m using windows 11 with mu editor
Trinket Mo flashes red twice
- adafruit_support_carter
Re: Trinket Mo flashes red twice
It sounds like you are still able to get the board into bootloader mode?
Are 7.3 and 8.0 are CircuitPython versions?
- Smurfcivic
I can program it using arduino but not circuit python
Are you able to access the serial console in Mu? To be able to see the CircuitPython output?
- Smurfcivic
yes this is what it says
- Smurfcivic
and heres whats on it
- IMG_4591.jpg (36.23 KiB) Viewed 194 times
OK, it looks like CircuitPython is generally installed and running fine. The two red blinks are indicating an exception:
https://learn.adafruit.com/welcome-to-c ... er-2978455
That'd be an issue with the code in code.py. There should be more lines shown above this:
In Mu, you may need to drag the top bar of the Serial window up to see more lines. Or try scrolling. Look for several lines that start with "Traceback" and paste those here.
- Smurfcivic
im not seeing what your describing
- IMG_4597.jpg (39.04 KiB) Viewed 188 times
- Smurfcivic
Now its showing memory error
soft reboot
code.py output:
MemoryError: memory allocation failed, allocating 1609 bytes
Code done running.
Adafruit CircuitPython 7.3.3 on 2022-08-29; Adafruit Trinket M0 with samd21e18
>>> [D
soft reboot
code.py output:
Code done running.
>>> [D
Thanks. Yep, that's the error:
The Trinket M0 is a pretty memory constrained device. So this unfortunately commonly comes up. In general, you're attempting something, in code.py, that's just too big, in terms of memory requirements, to run on that board.
What is your code.py?
- Smurfcivic
im building these. Mainly trying to use with the rotary encoder so my son can change modes on his glasses for trickrtreating
https://learn.adafruit.com/watchmen-sis ... ggles/code
Try removing all the text in the header comments of code.py. Those are just comment lines and are not needed for the code to run.
Look for this line (should be line 35):
and delete everything above that so that line becomes the new first line of code.py.
from math import modf, pi, sin
- Smurfcivic
ok trying now
- Smurfcivic
i believe that worked! about to solder the encoder back on and see
- Smurfcivic
Appreciate the help! I got them working finally after fighting it all week! Ended up messing up one board soldering to. Luckily I had a spare lol
